Checking Brakes Question
Thanks is advance,
PetePap
Is the sound coming from just one side of the car or both ?
1. You can purchase a type of anti squeal lubricant that goes on the exterior
(metal) side of the pads at the contact area of the slave cylinder and the clamping "forks" on the caliper. The stuff costs about a dollar.
Downside is you have to remove the caliper to apply it and you could replace the pads just as easily if you have gone this far.
2. There are metal spring like devices that are fitted to the rear (I don't know about the fronts but I bet so) These act to attenuate the vibration caused by pad against rotor. They do not affect the braking ability and if they were left off you would not know except for the noise.
3. I think some pad material is just more prone than others.Possibly the scoring on the rotor has some effect. Glazing (caused by overheating the pads during break-in) and or by petroleum products that have found there way onto the rotor surface and then onto the pad. You can try cleaning the components with brake cleaner.
I married a Volvo (they were notorious) in the 70's It squealed from the day it came new off the dealer's lot until the happy day I traded it for $1300 and
laughed all the way home.
I would try the anti squeal lube. It has worked for me. Unfortunately it is a pain to retrofit.
E500s probably have a different setup.
Of course, if non-OE pads are installed, you're on your own as regards squeaking.
Finally--unlike cheaper USA cars--the brake pad wear indicator is not a noise scraper but rather a light on the dash.
I got them done at the dealer, which was a rip off. I should call them and have them deal with it...at no cost...
Opinions?
pete
Thanks is advance,
PetePap
There is also piston dampeners, don't think they really do anything. Pink rubber filled with small BBs, they fit into the pistons.
Paste works the best when applied correctly.
Some places also apply stop squeal to the pad serface, works pretty good.
Some pads crack, which causes them to make noise.
Brake noise is very comon.
