E-Class (W211) 2003-2009
Let's play: Name That Sound!!!!!
Old Feb 22, 2008 | 04:27 PM
E500 AMG Sport's Avatar
Alright guys, after searching I wasn't able to find someone who had the identical issue.
Here's the Sound. After starting the car with the A/C button off but the vents blowing, there is a noise which sounds similar to a 12v. tire compressor coming from the front of the car. If I turn the blower off (set to 0) the noise stops. I can then turn the blower back on and it usually goes away.
Now mind you, the A/C compressor has never been on, so I don't think it's the auxillary fan noise people are referring to.
And yes, you can hear it from both inside and outside the vehicle.
Who will be the first contestant with the correct answer?
Old Feb 22, 2008 | 04:41 PM
Benz-O-Rama's Avatar
Flatulation Modulator.
Old Feb 22, 2008 | 04:56 PM
Nope, don't think so. Can't detect any intestinal gases!
Thanks for playing.
Old Feb 22, 2008 | 11:43 PM
georgedaman's Avatar
GL350
Does the sound stop when you turn on the AC?
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
This is one of the reasons I come here;Benz-O-Rama's toilet humor,hahaha
F@cking Brilliant....
Old Feb 23, 2008 | 10:47 AM
I believe it does make the noise regardless if the A/C compressor is on. What are your thoughts?
Old Feb 24, 2008 | 10:50 AM
vettdvr's Avatar
03 E500 and Corvette
air suspension pump leveling car
Old Feb 24, 2008 | 03:29 PM
No, the noise stops when I turn off the blower motor. It's definetly HVAC related.
Old Feb 24, 2008 | 07:50 PM
Barry45RPM's Avatar
2015 ML 350
Leaves/debris in the fan blower box.
Old Feb 25, 2008 | 12:56 AM
GL350
I complained about something similar and i was told that is is some kind of revers fan which only works when the AC is off..
