E-Class (W211) 2003-2009
Fenders rolled in Sac?
Old Mar 15, 2008 | 10:59 PM
fdee's Avatar
04 E500
Anyone know where i can get my fenders rolled in Sacramento?
Much thanks
F
Old Mar 15, 2008 | 11:05 PM
Benz-O-Rama's Avatar
Much thanks
F
What size wheels are you trying run? You can stuff 20" wheels on the W211 with no problem whatsoever.
Old Mar 16, 2008 | 12:29 AM
fdee's Avatar
04 E500
Greetings Benzo-o-rama
Actually I am running 20s. Lowered via star-diag. Wife was turning into drive way Lil to sharp I'm assuming and snagged the Lil lip inside of front fender.its not too bad and am thinking rolling would fix the snag and prevent from happening again.thoughts? Thanks
Old Mar 16, 2008 | 05:26 AM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
Slightly off topic .. how much can you lower your car via SDS? 1" right?
Did you have to get your alignment done again?
Old Mar 16, 2008 | 08:40 PM
What size tires are you running?
The proper size is:
245x30x20 fronts
275/285x25x20 rears
If you run these sizes, you should see no rubbing.
And Vik, every car is different when it comes to lowering with SDS. I got about an inch and yes, you do need to do an alignment with it.
