need help! Terrible Idle
When the car is in park or any gear it will begin to shake very badly. When I start to accelerate it stops as if nothing is wrong. I am getting terrible gas mileage though. I have replaced the motor mounts so its not that. I also replaced the fuel filter/pressure regulator. Could it be the fuel pump? PLease help!!!
If the MAS is going bad it will throw an ambiguous 0170 error code!!! Shaking could also be bad engine mounts but not if the fuel economy is bad!Scope the engine or pull some plugs and take a look...
motor mounts
air filters
maf
plugs
fuel filter/regulator
The car was running amazing then one night i pushed the car a little bit accelerating quite hard.. when i got to a stop the car began to idle horribly.
I am thinking it is the fuel pump
If you can't scope the engine the you could also pull the ignition wire from one spark plug/ cylinder at a time while the engine is running and the BAD plug/coil/wire will have no effect or drop in rpm.
The other thing to check is the O2 sensor... how many miles do you have on the car? If the engine is missing badly the raw gas will kill your catalytic converter!
Like someone else said.. check the ERG valve to see if it is stuck closed.
Did we miss anything else?
OH.. almost forgot... happened to my E260 once... it has a leakiy fuel distributor !!! Hopefully not, 'cuz it is Expensive... I think you take a flashlight and look down pass the Throttle body and if it is "all wet" then the FD is leaking.
