E-Class (W211) 2003-2009
Strange (Part-Time) HID Error
Old May 7, 2008 | 02:33 PM
djmallya's Avatar
03 E320/ 11 E550 Cab/ 18 E400 Cab
I recently had an HID kit installed at a local shop. Every once in a while (1 in 10 night starts) only the left headlight comes on and I get an error message that the brakes have malfunctioned... stop the car immediately.
And when this happens the brakes don't work so if you're currently driving...
If I turn the car off and on again, everything's fine.
What could this be? And should I really trust the same aftermarket HID shop to fix it?
Old May 7, 2008 | 02:53 PM
ss3964spd's Avatar
2011 E550 (RIP), 2014 CLS 550C4
Don't HID's draw a LOT of current upon start up?
I believe I've read in this forum that weak-ish batteries are responsible for all sorts of electrical gremlins in these cars, including SBC shutdowns.
So, my guess, and it's really just a SWAG, is that perhaps the high initial current draw of the HIDs starting is dropping the available battery amperage low enough to cause the system to think there isn't enough to power the SBC.
Dan
Old May 7, 2008 | 03:36 PM
djmallya's Avatar
SBC?
Old May 7, 2008 | 04:28 PM
ss3964spd's Avatar
SBC = .....hum, come to think of it I'm not completely sure what the acronym stands for, but it's MB's electronic braking system.
Old May 7, 2008 | 05:06 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by djmallya
SBC?
Sensotronic Brake Control
Old May 7, 2008 | 06:06 PM
W Cole's Avatar
makes your daughter horny
Did they install the ballasts by the SBC unit? My best guess is the ballasts are giving off electronic noise.
Old May 7, 2008 | 07:32 PM
RONB's Avatar
2012 E63 AMG Wagon
did the HID come with capacitors? That could be the problem... no balance in the electricity since the car is not xenon ready.
Old May 8, 2008 | 02:45 PM
djmallya's Avatar
I'm not sure, what does it look like/where is it?
Old May 8, 2008 | 02:48 PM
djmallya's Avatar
Yes, I think so. There were 2 boxes for each bulb, note sure exactly what they were but I would imagine that one had to be a capacitor as I do not have a flickering problem.
Old May 12, 2008 | 11:58 AM
djmallya's Avatar
I think this was the problem.
When I mentioned this, they said that there was no way this could be the problem and they tried rewiring the lights to the accessories battery. All this did was give me a battery warning light as the small battery was not strong enough to power the lights. But the original problem remained.
In the end I had the HIDs removed and the problem went away.
