A question and a few pics to see if you like!
thanx guys,
ooh, here are a few shots of my new rims, you guys like???
https://mbworld.org/forums/attachmen...1&d=1217806712
https://mbworld.org/forums/attachmen...2&d=1217806712
https://mbworld.org/forums/attachmen...9&d=1217806712
https://mbworld.org/forums/attachmen...0&d=1217806712
I think your problem is the motor mounts. IIRC, it's a common problem with the earlier W211's
How's the weather in Guatemala? Apparently, rainy.
elasticity over time, but if you add salt to the equation (like here in Toronto),
then the lifespan is definitely shorter.
not lots of help, but I'm still new here
G.
I'm having a bit of a hard time buying into the notion that a failed engine mount will cause the engine to shake more at idle. Seems to me that if the engine were running correctly at idle (fuel pressure, clean injectors, ignition system, no vacuum leaks, sensors within tollerance, etc) the engine would idle smoothly, even if sitting on solid mounts.
Dan
They were replaced under warranty because of a rough idling problem. There's a DTB out for this, I believe.
and was excited but after seeing yours, makes me wish I went for
your style or the new E63s car color is techtite grey? )
e
yea its tactite grey....!
ok, so change motor mounts, is that labor intensive? Expensive parts included?
thanx
