"Close Sunroof" message on IC
I was in a freinds 2004 E500 today and a message showed up when the car was turned off on the IC to close sunrrof. Is this a feature that can be turned on via SDS on a 2003 W211 ? My car does not display this message.
Do you really care about that message? It turnes off as soon as you leave the car and lock it. Once you come back it tells you that again and you start the car and it is off again b/c your in the car and driving and you intended to open the sun roof and while outside the car it is off as well.
I rather cared about that stupid SOS message b/c I don't have a TeleAid subscription. So I know that can be turned off and so I did.
Former Vendor of MBWorld
some slow@$$diesels
the first couple ICs didn't come with that message (2002, 2003) - the later IC versions do come with that message - nothing to do with the stardiagnose settings.
I actually do like that message (2005 IC in a 2002) being that I live in a country where it rains a lot and I forget to close the roof every now and then (depending on the wind it CAN get VERY wet in the car with just a tilted roof).
greetingz,
greetingz,
greetingz,
greetingz,
209/W210 Estate /W211 modded by MBENZNL
Go for the AMG CLS63 Instrument Cluster
That function along with a lot more
200MPH Speedo
Lap Timer
Voltage/Oil Temp
Calendar day/month/year/
And Looks a LOT better
That's it on more infos for 750 USD? Thought there is more to see! 200 mph speedo for US Lap timer for what? Voltage/Oil Temp Calendar?
2003 E500
Received 4,415 Likes
'71 Pinto
Not the best but you can get an idea from this brochure illustration.
BTW I will respond to your installation request tomorrow.
2003 E500
