E-Class (W211) 2003-2009
Bluetooth adapter question
Old Dec 11, 2008 | 12:01 AM
Greg_S's Avatar
2008 E550
there are 2 part numbers for these units. the one that ends in 78 is said to be newer than the the one that ends in 39. Is that true and is it any better? I'm looking at getting one off flea bay and pay about half of the dealer charge.
Old Dec 11, 2008 | 12:13 AM
Mackhack's Avatar
The only BT module I know has the part number B 6 7 87 5855 and is for 2003/2004 E Class with analog TeleAid.
Old Dec 11, 2008 | 01:14 AM
Neoii's Avatar
e500
I'd go for the "78" if you have a choice.
Old Dec 11, 2008 | 02:04 AM
Diesel Benz's Avatar
See here, also US adapters listed:
http://www.mercupgrades.com/Mercedes...article-9.html
Old Dec 11, 2008 | 02:51 AM
155's Avatar
155
R350
I just placed an order today for B 6 7 87 5855. Hopefully this is the current part #...
Old Dec 11, 2008 | 11:42 AM
Greg_S's Avatar
2008 E550
I am going to get the newer unit, thank you for the responses.
155 - Nice to see you have a Duc, do you track it? I have a Sport Classic that I set up for the track and just picked up a 2005 999S for some track duty next year.
Old Dec 11, 2008 | 03:23 PM
155's Avatar
155
R350
Greg - I ride the track only! Too many close calls on the street...
Primarily we do Pacific Raceways in Seattle and Portland Int'l Raceway in Portland. We also ventured off to Miller in Utah for 4 days. That was an incredible trip! We plan to go again next year.
The 05 999S is a really nice pick up as you get the braced swing arm, higher output motor and a few other tweaks. Supposed to be much better then the 03/04's. Congrats!
There are a couple "must-do" track mods for the XX9 bikes:
1) DOT race tires or slicks (the Dunlop 211's, Ntech's are brilliant)
2) Yoyodyneti quick throttle (stock is WAY too long)
3) Brembo brake master cylinder/race pads
4) 520 chain conversion (check message boards for optimal gearing)
5) Suspension setup by pro (geometry, dampning)
Are you on Ducati.ms?? Speedzilla forums are okay too.
Pictures:
MILLER (on friends GSXR750)
PR (on Duc)
PIR (on Duc)
