E-Class (W211) 2003-2009
Aardvark
Old Jan 5, 2009 | 09:29 AM
aardvark's Avatar
1996 e-320
Aardvark
Interior light fuse on 96 e-320 keeps blowing
Just joined up.
I see a lot of good info here and was kinda hoping for a little help.
I have the number 3 fuse under the back seat blowing out and killing all interior lights(dash is not effected). It is listed as lights/cpu. It initially blew out, and l replaced it, and it lasted for 2 weeks. Since then, the blow out time has been faster and faster. Last fuse went an hour.
Any thoughts? I've looked over some of the lighting fixtures and havens seen any frays or burns.
Thanks in advance. The posting on the heating fan portion was quite helpful.
Aardvark
Old Jan 5, 2009 | 09:38 AM
philfna's Avatar
GL350-Bluetec P1
Have you tried a larger fuse. On my BMW I put in a fuse that had a higher rating, and it has held for years now. It is a 99' and around 2003 it started with the same problem. Otherwise obviously some component is causing an overload.
Old Jan 5, 2009 | 09:50 AM
aardvark's Avatar
1996 e-320
No, I sorta fear frying more stuff by overfusing.
Not the best practice, and would prefer to find a cause, rather than taking a chance
Old Jan 5, 2009 | 10:02 AM
aardvark's Avatar
1996 e-320
I was sorta in hopes of the obvious, yet most times I overlook the obvious. At least I went looking for a fuse. Last fiasco I did was start searching down wires for a burned out running lite bulb. Sure felt stupid that day when I finally looked at the bulb. DUH!
Aardvark
Old Jan 5, 2009 | 10:14 AM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Aardvark
You might get some helpful information in the W210 forums, since your car is a W210. This could be a known issue.
