Good-Bye Yellow Parking light, Hello LED
2006 E500
After several attempts to change out the incandesant bulbs with ones that match the OEM HID, I found a fast and simple soultion under <$25 and 25 minutes.
STEP ONE Buy (2) 5 Watt 100OHM resistors from http://www.autolumination.com/
STEP TWO Buy (2) Wedge T10 White LEDs available from ebay: http://cgi.ebay.com/ebaymotors/_Car-...1%7C240%3A1318
STEP THREE Splice in the resistor inline on both pos and neg side of the parking light (you will have extra length on the wire harness if you take out the hi-beam). Each connection will have (3) wires joined together and two splice per light. Reccomend cutt/splice rather then inline splice for soild connection. Wrap with black electrical tape and install T10 LED and reinstall into housing. Total time 12-15Min per side.
Thats it! Its bright matches the oem light AND NO lamp failure indication.
Email with questions!
I got mine here and they look similar to the ones you installed. No error codes whatsoever. No resistors to install. Just plug and play. Have had them on the car for several months.
I did however install those same resistors that the OP used for the led license plate bulbs. Those work great and no error codes on those either.
http://superlumination.com/images/au...otector_wm.jpg
Attachment 148592
Attachment 148593
Attachment 148594
Attachment 148592
Attachment 148593
Attachment 148594
your dont look match ...u should get super white instead of blue
I kinda like the yellowish parking lights and how the offset the HID running lights. Just me I guess, but the parking lights match my clear corner bulbs which are basically yellow and my Brabus fog lights so I think I'll keep em'. Thanks for the writeup though I'm sure people will benifit from it.
2006 E500
Im confused the diagram said u only need to connect to the Ground wire,
Yea, its never as easy as they say. its such a small amount of cash and time for a completely new look! well worth it. I am changing the fog and high beams to PIAA H7 and 9006 this weekend so all the front lights match!
2006 E500
Attachment 148592
Attachment 148593
Attachment 148594
Attachment 148592
Attachment 148593
Attachment 148594
Attachment 148592
Attachment 148593
Attachment 148594
Attachment 148592
Attachment 148593
Attachment 148594
do i need to do this resistor splicing when installing 16-LED license plate bulbs?
http://cgi.ebay.ca/ws/eBayISAPI.dll?...#ht_1804wt_905
ordered them off eBay. should be bright as heck =D but i dont want to deal with the errors and whatnot.
Attachment 148592
Attachment 148593
Attachment 148594
Attachment 148592
Attachment 148593
Attachment 148594
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Steve
