E-Class (W211) 2003-2009
Radio on with key out of ignition?
Old Feb 6, 2009 | 11:23 PM
mhj202's Avatar
2014 GL450
Pulled my 2009 E350 into my garage this evening, took the key out of the ignition, opened the door and realized that I needed something out of the glove compartment. As I leaned over to get to the glove compartment, I accidentally hit the power button for the radio/navigation/comand system and the radio turned on. I had no idea that the radio, etc. were still powered after the key was out of the ignition and door was opened.
Is this normal?
I assume that I could look up the answer in the manual but I don't have it handy.
Thanks.
Old Feb 6, 2009 | 11:25 PM
Polar Bear's Avatar
W221 S600, W220 S55 AMG Kompressor, W124 300E, W140 S320, W210 E3204M W164 ML320 Bluetec
Is this normal?
Thanks.
Yes, this is normal. Mercedes-Benz cars have done this since at least the mid 1980s if not earlier.
Old Feb 6, 2009 | 11:33 PM
mhj202's Avatar
2014 GL450
Thanks! My previous cars (non-MB) usually kept the power to the windows and radio after the ignition was off and key was out of the ignition but then cut off when the door was opened.
Old Feb 6, 2009 | 11:49 PM
Dema's Avatar
i535
I think it is a good feature of Benz, you can turn on radio any time without carying keys. BMW behaves differently, you stop engine and leave car, however radio will continue working about 5 minutes and then you need keys to keep it up.
