E-Class (W211) 2003-2009
Is there limit on how many mp3s in-dash CD can play?
Old Mar 27, 2009 | 11:56 AM
finnjab's Avatar
04 E320 Wagon
I burned a DVD-R with about 1,100 mp3s and popped it into in-dash CD. Everything seemed to work fine. I could see and access all the folders. However, beyond a certain folder, it wouldn't play the songs in that folder, even though I could see them. With some trial and error, I discovered that roughly beyond 825th mp3 (it is not very accurate since the system also counts folders as items), it wouldn't play them.
Has anyone experience this problem? Or knows that there is a limit on number of mp3 on DVD?
Thanks.
Old Mar 27, 2009 | 12:00 PM
Benz-O-Rama's Avatar
Thanks.
I may be wrong, but I think it'll only play songs in the first 99 folders. Try just dumping all songs into one folder and see what happens.
Old Mar 27, 2009 | 11:59 PM
Dema's Avatar
i535
Right suggestion. Do not put files in root directory, create subfolders.
Old Mar 29, 2009 | 12:19 AM
djjoonie's Avatar
AMG GTs
ur 04 can play mp3's? mine is 04 e500 4matic, and i couldnt get it to play mp3's,, when i went to get my tranny service done , i asked them if my unit software can be updated to play mp3's they said only 06 and up can be updated.. is this true? or they got no clue
Old Mar 29, 2009 | 07:41 AM
Yep, not only will it play mp3, but I have one of the 04's with a dvd rom, so I get to play mp3's on a dvd.
There is a service tool disc that will upgrade your COMAND to enable mp3 playback, as well as a few nav features.
Search in this forum, all the info is there.
Old Mar 30, 2009 | 07:28 PM
djjoonie's Avatar
AMG GTs
i just downloaded the update files and updated the command unit myself. it is now working flawless thanks!!
Old Mar 30, 2009 | 11:22 PM
Yeah man.
Old Mar 31, 2009 | 09:30 AM
unclebenz's Avatar
I have the in dash cd changer in my 03 E500 but it doesnt play mp3's, is there a way to convert it or do I need a different unit?
Old Mar 31, 2009 | 09:45 AM
Nah, that one won't play mp3s, the newer ones will. You have a 2003, so I don't know if you can convert without going with the full COMAND system. My R500, for example, will play mp3 discs in the single slot and all 6 changer slots, but won't take a dvd. My E500 will take play mp3s on a dvd in the single slot, but only play regular cd's in the changer.
It's very confusing.
Old Mar 31, 2009 | 01:12 PM
ruffrob's Avatar
2010 Charcoal Grey E350 Coupe
You can say that again,My upgraded box plays CD's in the single,and MP3 CD's in the changer ,but I'm not complaining....
Old Mar 31, 2009 | 01:16 PM
Wait...
You have the APS50, right? And you upgraded the cd changer to one that plays mp3's? If so, then Unclebenz is in business if he upgrades his changer.
Old Mar 31, 2009 | 01:34 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
Thanks.
Directly from my COMAND manual:
Max of 255 files per folder.
Max of 255 folders.
I can confirm the max 255 files per folder.
