E-Class (W211) 2003-2009
I'm scared of SBC pump failure - Any precautionary measures to avoid this ?
Old Jun 22, 2009 | 05:20 PM
007_e350's Avatar
X166 gls450 2017
Folks,
I came accross a few stories of SBC failure, and how guys pulled onto the shoulder with foot on the parking-brake and someone upshifted the gear etc ... this is in the event when there's margin infront of the driver .... What if there isn't & you need to say stop on a red light ? Its our life on the darn SBC pump
Question to all Gurus, how can I prevent this failure ? Is there a specific period after which I should swap out the pump -or- would it show signs of failure prior to failing (If yes, what are they)
I guess this (SBC failure issue) would top the charts when it comes to Benz unreliability
Old Jun 22, 2009 | 06:53 PM
Barry45RPM's Avatar
2015 ML 350
It may fail... it may not. There's no work-around for you to make it last longer, short of not using the car... in that case it would last forever. Its warranted for 10 years by MB though. They won't change it out while its working perfectly for you.
Just use the car.
Old Jun 23, 2009 | 03:43 AM
stickygreen's Avatar
'97 E320
I wouldn't worry about it as failure rate appears to be VERY minimal. In fact, the brakes are quite a bit better in our '05 cdi than in the '97 e320 or '09 GL320
Old Jun 23, 2009 | 04:05 AM
Scraz51's Avatar
2003 E240
Has it happened to any friends of a friend or is this just something we read about on the net etc that may happen but is very rare?
Old Jun 23, 2009 | 11:16 AM
vettdvr's Avatar
03 E500 and Corvette
It happened to me in our 2003 E500. When it does you get a RED warning stop car in the FSS.
This happened to us while driving very slow in traffic and we pulled over to the side and called MB for a tow truck. The entire SBC system on our car was replaced under the MB warranty.
So this is not a joke or myth. While my car was at the dealer another came in with the same problem. So I would not discount this as infrequent. I noticed you had a 2007. I didn't think the 2007 had the SBC, I thought MB dropped it in 2006.
Old Jun 23, 2009 | 08:55 PM
Scraz51's Avatar
2003 E240
Hmm that is really scary... haha I dont want to drive.
How many miles had you done before this happened?
Old Jun 24, 2009 | 07:32 AM
vettdvr's Avatar
65000
Old Jun 24, 2009 | 09:02 AM
Scraz51's Avatar
2003 E240
That is a tad bit frightening haha.
Old Jun 24, 2009 | 09:11 AM
novae500's Avatar
W211
I have 32k on mine and under warranty thru 2013. So i hope everything that vettdvr has come across all happens before my warranty runs out. If not, i will be in the poor house.
Old Jun 24, 2009 | 10:06 AM
erifly's Avatar
I think the SBC issues were with 2003-2005 models. I'm positive they don't effect 2007+ and I think 2006 is nearly identical to 2007 underlaying(just a different face)
Old Jun 24, 2009 | 10:12 AM
Barry45RPM's Avatar
2015 ML 350
The '06s still had SBC. The '07s Did not, so the SBC dependability issues remained. However, there had been several electrical service updates which MB had come out with relative to the systems wiring/connectors, but the overal SBC system was still part of the '06s and no 211s from '07 on.
Old Jun 24, 2009 | 01:11 PM
gaazmon's Avatar
2009 SL550 Roadster Diamond White, 2008 CLK550 Coupe Obsidian Black
On 07+, only the AMG have SBC. 06's still had it. The same goes for the CLS. Idk about the SL if they took it off in the 07+ cars minus the AMGs.
I had my pump replaced at 53,000 miles under warranty. The thing began making a lot of noise. So took it to the dealer and he just said they'd swap it out.
Old Jun 25, 2009 | 12:10 AM
007_e350's Avatar
X166 gls450 2017
Guys its not about replacing the SBC pump (Its under warranty for 10 yrs) ... Its our lives on that Pump .... and there is no specific maintenance / replacement period for this thing, they won't replace it till it fails - wow! Aint that nice ?
