DIY Oil Change
Now most of us don't have a dip stick extractor, so draining is still the only option, which is fine. The "55" engines have 2 drain plugs that must be replaced each time. Not just the washer, but the whole plug. But those engines also allow for the suck method.
Assume you will find a plastic shield, but it is likely a little different. The oil pan may be exposed and you do not need to remove anything.
