Question? - Does ayone know if the govener be remove or increased above 135mph?
03 E500 B. Silver/Ash
rich
'01 E55
'99 ML430
'96 993 C4 Cab
We pick our ride up today or tomorrow. I understand the E500 sport is shipping currently with the "H" tires and the 130 mph limit. Reason quoted on other threads was that the "W" rated tire was wearing poorly and MB was getting a lot of flak over this.
It does seem that most people with the Sports version are reporting that they received the "H" tires.
Ed
Question? - Does anyone know if the governor be remove or increased above 135mph?
The speed limiter (often called VMAX) can be changed or removed completely. This process requires chip re-programming and is ill advised unless you change your tires from the garbage H tires that MBZ sees fit to dole out to the USA. Liability may also be a problem- we will not touch the VMAX in the USA for this reason.
