E-Class (W211) 2003-2009
W211 Head Unit with Navigation
Old Feb 9, 2010 | 01:19 PM
benzso's Avatar
E63
I just installed an after market head unit and have the original stock w211 command head unit with the NAV drive for sale. PM me if anyone interested.
Old Feb 9, 2010 | 02:00 PM
Badabings's Avatar
2007 E63, ML350
What after market unit did you go with? I've been thinking of doing the same thing. Any pics?
Old Feb 10, 2010 | 07:40 PM
E55 AMG Black's Avatar
E55 AMG
Unit/Nav
Benzso, how much are you asking> I have an 04' E55
Old Feb 11, 2010 | 12:14 AM
benzso's Avatar
E63
PM Sent
quote=E55 AMG Black;3934061]Benzso, how much are you asking> I have an 04' E55[/quote]
Old Feb 15, 2010 | 02:34 AM
BFC - Hayden's Avatar
2003 E500
I'm sorry - complete noob to W211's here...but does this plug and play into W211's that didn't come with nav from the factory?
Old Feb 15, 2010 | 01:22 PM
benzso's Avatar
E63
You should be just plug it using the existing wire from your current head unit
but I will suggest you to have the professionals to install it.
Let me know if you are interested.
Old Feb 15, 2010 | 03:24 PM
2003 E500
Can anyone else confirm that it's just a harness swap? Will it even fit?
Old Feb 15, 2010 | 04:35 PM
benzso's Avatar
E63
I am sure it will perfect fit. I used to have the 2003 Silver E500 Sports.
As for the installation, i will suggest you find a local audio place that have experience with Mercedes. They should be able to install that for you.
Old Feb 17, 2010 | 01:19 AM
Dtv211's Avatar
E320
How much for nav drive, bracket, splitter and carpet?
Old Feb 17, 2010 | 01:26 AM
benzso's Avatar
E63
I am selling both head unit and nav
the nav was pre-installed by Mercedes
located in the left side panel. When i removed it
I also removed the bracket. I can ship that together
if u need it. I am not sure what u mean by splitter and carpet.
I am only selling both devices. Younshould
be able to connect it using your factory cables.
Or I will suggest u to have the professional install it.
I really don't know how to connect this things lol.
Old Apr 5, 2010 | 01:03 AM
Jheedley's Avatar
2003 E500 W211 Sport
Do you still have the u it(s) for sale. I've just acquired a2003 E500 sport and am interested in getting a stock navigation unit. If you still have it, I'm very interested.
Thanks,
John
Old Apr 5, 2010 | 10:37 AM
E320 Newbie's Avatar
Now a 2007 E350 4matic
Nav Fit
If you check the Audio forum, there's several step-by-step listings with pictures showing how to retrofit the Navigation unit.
The Splitter is for the Satellite Antenna signal.. it IS required.. it replaces an antenna junction located on the top left panel behind the carpeting, near the trunk hinge. It splits the Sat antenna between the teleAid and the Nav unit. (even if the tele aid is not active or used, you need the splitter or you'll get errors)
There is also a fiber optic cable that needs to be connected to bring the Nav unit into the MOST network. It's usually located under the rear passenger door sill or in the C Pillar.
I did retro fit on an 03 E320. Since the side carpet panel wasn't available anymore, I mounted the Nav unit under the rear shelf.
You'll also need the Navigation Disc
Installation was fairly easy.. took about 2 hours.
Old Apr 5, 2010 | 02:16 PM
benzso's Avatar
E63
Sorry john, that was already sold.
Thanks,
John
Old Apr 5, 2010 | 03:03 PM
Jheedley's Avatar
Thumbs up Thank-a-million
@ E320 Newbie - that is very very helpfull. I cant wait to get all the pieces together and do the swap. Now just to find them all
@ benzso - Thanks for the reply - I'll keep my eye open for the next great deal.
