LOVEMYBS |
03-29-2010 09:10 AM |
Caution-Frozen Valve Stem Caps
Yesterday I wanted to check the tire pressure on my wife's BMW X3 that came wirth a tire pressure monitoring system (TPMS). When I tried to unscrew the first metal BMW valve stem cap it was frozen and the rest were the same. I couldn't even get it off with a pliar and may have stripped the head. So I called the dealer this morning and they said you should not put metal valve stem caps on a car with TPMS because they will freeze/rust in place. Trust me, it's TRUE! You should only use plastic or rubber valve stem caps. I also have AMG metal caps on my SL (my BS does not have TPMS) which explains why they are so difficult to unscrew. Just a heads up to avoid a future and potentially expensive problem.
