Last edit by: IB Advertising
See related guides and technical advice from our community experts:
- Mercedes-Benz E-Class: How to Replace Brake Fluid
Step by step instructions for do-it-yourself repairs
Would you change brake fluid at 20k?
GL550
Just hit 20k on my 2009 E550. I do most of my own maintenance and am going through the sheet and it says to replace brake fluid every 20k. Would you do it? If not when should I? Thanks
Pat
Pat
205, 211 V8 4M, B7 /RS4, e30 ///M3
atleast u dont got SBC. i want to flush mine too but im so confused with this SBC and i dont wanna upset it, bc it might cost me a couple grand..
anyone got tips on flushing SBC?
Mike....
I could be completely wrong, but the sbc is just another unit in line with the abs unit. I would think that you would have to power flush the brake system from the master cylinder down to each wheel. It should be the same procedure as in vehicles with just abs systems.
Mike....
Mike....
If you're doing the work yourself, do what MB recommends on "the sheet" ... i mean they only BUILT it .. what do they know, right?
2008 ML350 4matic
A member in another forum recommends this....
http://store.motiveproducts.com/shar...ount2=92383980
along with ATE gold brake fluid.
His instructions were to pressurize the unit and open each caliper bleeder screw individually until the air bubbles were out of the line. The ATE fluid is a different color and is apparently obvious when the new fluid is flushed through.
The OP suggested to open the furthest screw from the master cylinder first and so on....
03 E500 and Corvette
If your car has SBC brakes use only MB Approved brake fluid.
Any non approved fluid might give MB reason to decline any warranty claims on the 10 yr SBC extended warranty.
Check the owners manual. I bought my fluid from mercedes to prevent any issues.
Sorry your brakes arent' important enough to use approved fluids.
I'm sure you have enough information to solve your issues.
Bye!
The indy shop here quorted $80 with original Mercedes brake fluid and take only 40 mins... I think i better do it .... my car has 80k now ! only flush the cooler...
09' E350 AMG Sport, 09' C300, 03' Honda S2K
Might be silly question, but where is our brake fluid resevoir. Is it the one right beneath the driver side intake in the engine bay? I wanna see how clear it is because I just for my brake flush.
I flushed my SBC brakes about 6 months with very good results and the fluid is still clean. (NOTE did the job Without STAR)
I used the motive pressure bleeder w/MB adaptor. Filled bleeder with new fluid. Suction as much old out of the master cylinder, then top off fresh.
Install bleeder and pressurize.
Bleed brakes in correct order on each wheel.
After bleeding each one check to make sure you still have fluid in the bleeder.
Do all 4 wheels.
Took almost 2 ltrs of brake fluid to do total job.
After 6 month or more the fluid is still clean.
I didn't unplug the sbc but feel free to do so if you chose. But remember you aren't opening the pads only the bleed screw.
Do all 4 wheels.
Thanks ! Was the MB adapter the single one that Motive says fits most European cars, or did you get the kit w/an assortment of adapters that contained a MB specific?
