RED WARNING "Braking effect reduced/Increase braking distance" =)
2001 CLK55
So I had the regular "Check brakes visit workshop" warning on for a day then Saturday...The big red one that says "Braking effect reduced/Increase braking distance"
So after some research and help from Konigstiger I got my whole SBC unit replaced in 6 hours, got my oil changed and a wash, reset the "Restraint defective" code cleared, replaced brake switch all for 58 dollars!
If you guys are in the Upstate NY area you should bring your car to John Holtz Mercedes. I highly recommend them.
I would like to know if that pump actually has a counter that trips into default when it has been actuated a pre-set number of times? I read this somewhere and since I intend to keep the car for a lot longer, it is likely that I will exceed the warranty period before it fails. Since this was not M-B finest hour, I do not know what to believe. I guess I should start looking for one on flea bay just in case. I wonder if it can be rebuilt?
I can foresee the a brisk business in rebuilt units, if they are not sued out of existance.
03 E500 and Corvette
Conversion to conventional vacuum with install kit would be better choice. But then who speaks enough of German to reprogram the computer to accept the conversion.
2001 CLK55
supposedly the tech told me there is a counter...and instead of being set to 300k, it was at 30k, not sure how true this is. I just wish they just had "regular *** brakes" too much assisted braking anyways. Oh well.
I did some checking on Dogpile. There does appear to be a consensus that 300,000 "activations" is the service life for the pump. Reportedly, it will throw an error code and require replacement. I find it interesting that:
1. The part creates a fault because it has a pre-programmed service life.
2. That intended consequence is diminished braking capacity. So if I am coming out of Estes Park CO and my time is up, I need to look for a runaway truck ramp?
3. There are people in the world "overhauling" this part by resetting the counter.
I would very much like to perform an autopsy on one of these things but I bet that M-B / Bosch keep them under lock and key until the defective ones are destroyed.
I guess in this circumstance breaking capabilities are 2 a penny
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
Steve
I do not know how they reset it. They require it to be removed and shipped. I think it was a UK operation. Since even the first MY are still under time warranty, I guess this "service" is not in big demanand in the US. I saw a brand new pump for $500 on e bay the other day. It was tempting to stockpile for the future. I cannot guess which way the price might go as parts for older cars usually drop for a while and then climb as the stockpile diminishes, sort of a negative of the bell curve. As the cars drop out of warranty, I am guessing the demand for pumps will rise and so will the price. I really wish someone would publish the real facts about these things. They are the achilles heel of the older 211's
