Warning Triangle W211
Anyone have the part numbers for the warning triangle and bracket that came on pretty much all non-US cars? My car is a 2009 E63.
I found some on Ebay.de but none of them have a bracket. |
A2118900814 for the bracket and A2118900397 for the Euro triangle.
I also bought A0039948745 Washer and N000000000528 Screw in conjunction with DBs list to complete the factory install look. Probably not necessary but kept it OEM that way.
Steve at MBENZNL!
Thanks for the help!
I assume I can carefully cut holes in the existing liner to make it all fit... |
Yes. If you remove the liner from the trunk lid you should see the indentations on the backside. It makes for an easy to follow cutting guide.
If you have a W211 wagon, there's a small niche on the left panel in the cargo compartment where the MB warning triangle fits and is held tight by a Velcro closure. The part no. for that triangle is: 168-890-079. However, my local MB dealer here in the US said he could not order the part so I had a friend buy it for me in the UK and bring it over. Perhaps another US dealer would be able to order it.
Originally Posted by amdeutsch
(Post 4060565)
(Post 4060565)
Originally Posted by Oggie (on L.I.)
(Post 4062858)
Originally Posted by RichardM98
(Post 4063679)
I got the same story from my dealer when asking about the warning triangle for my W210. Not available in US.
Originally Posted by hgerhardt
(Post 4063669)
Only (1) each Washer and Screw required?
I would definitely recommend R & R of the liner instead of leaving it in place and attempting to cut it out.
(Post 4062872)
Can these parts be used to attach the warning triangle to the trunk liner of a non-Mercedes or are they contoured in some ways to fit only a W211 sedan?
(Post 4060565)
The two parts you have listed come up as the following: A0039948745 Washer comes up as a mb splash guard fastener? I assume these are probably used through out different applications. Does this seem right to you? https://www.mboriginalparts.com/oem-...nut-0039948745 The screw comes up as nothing anywhere on MB sites. I found something on ebay. But wondering if this is correct? N000000000528 https://www.ebay.com/itm/FREIGHTLINER-SCREW-N000000-000528/131981910092?epid=523295604&hash=item1ebabc204c:g: HZIAAOSwWzVbqf9Z:rk:1:pf:1&frcectupt=true EDIT: Found this for the bolt/screw? Is this correct? https://www.benzpartsonline.com/oem-...w-000000000528 Thanks, -Nigel |
Got my triangle and bracket. I cut the liner in the trunk. Now just waiting on a couple bits for the mounting of it and we'll be good to go. I hope to get them next week.
I'm surprised at how heavy this triangle is. I thought it would be light and flimsy and it's got some heft to it. https://cimg5.ibsrv.net/gimg/www.mbw...55f280500c.jpg -Nigel |
