E-Class (W211) 2003-2009
Old Jun 15, 2015, 07:27 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Cooling System Guides
Print Wikipost
I am confused about replace the coolant
Rating: Thread Rating: 2 votes, 5.00 average.
Old May 26, 2010 | 11:50 AM
hatplus's Avatar
2006 E-350
Hi! everyone..
I have a 2006 e350(w211) 63000 miles now
I want to replace the coolant. but I checked some thread
W211 coolant replace interval is 15years or 1500000 miles.
Also I found this article.
Is it true?
So I must wait 9 years or 90000 miles ?
Please help me . I am confusing...
Thank you very much
I ordered MB coolant 1 gallon.
The coolant is in fact blue/dark green, the coolant must remain in the cooling system for the specified interval. There is a silica pack in the coolant tank that maintains proper additive levels for the life of the coolant. MB uses "HOAT" coolants and have absolutely nothing in common with the "change the coolant every year" types (IAT/OAT) that went away with the Jurasic period of automotive technology
I strongly suggest NOT opening the system or adding anything to the system. If your engine tells you that the coolant level is low then add ONLY distilled water and always consult the owners manual.
Coolant changes are peformed every 140,000 miles and not any sooner. When the coolant is new it reacts with the engines metals forming a protective layer and achieving a balance in Ph. Adding coolant or changing it early throws off the balance and can cause increased corrosion due to the change in initial Ph of new coolant.
Old May 27, 2010 | 12:52 PM
lkchris's Avatar
'10 CL550, '12 GL550
Don't worry, be happy.
MB engineers know more than you.
Old May 27, 2010 | 12:57 PM
werewolf34's Avatar
2009 E350 Sport
I am skeptical that any fluid would be good for 15 years
Old May 27, 2010 | 06:20 PM
CharlyE500's Avatar
E55 2006 / CLS55 / S450 / Jag XKR2011
I flush mine cooling about 5 months ago. My car is 06 E55 and paid $85
Mercedes Indy shop did for me and it was authentic Cooling fluid from MBenz. I think the color is transparent. The original was Blue...
And so far my car operate the same...
Old May 28, 2010 | 11:14 AM
paulv's Avatar
03 E320 -wife's car now; 07 Porsche Boxster S - my toy
Why don't you send a sample to Staveley and get it analyzed:
http://www.staveleyfa.com/public/FLlabtesting.asp#four
Regards,
paul...
Old May 28, 2010 | 12:37 PM
lkchris's Avatar
This based on your PhD in Chemistry?
Old May 28, 2010 | 03:43 PM
werewolf34's Avatar
2009 E350 Sport
No, it is based on a blind faith put in MB engineers who chose such marvels as SBC and the valeo radiator for your e-class.
Your name isn't Walt, is it? Do you teach high school chemistry and run a 'side business'? If so, I will take your word for it.
Old May 28, 2010 | 04:00 PM
SZMB's Avatar
2004 E500 CLK320
I would change the coolant at 100k mi. Aluminum engine blocks are not as rustic as the old generation iron blocks. BMW recommends coolant change every 4 yrs. MB has been playing around with the numbers game for a few years now. Not long ago, they said the tranny fluid was lifetime that never needs to be changed, then back down to 100k mi, and now 40k mi. The oil change interval was around 15k mi, then back down to 12k mi, and recently they updated the car's software and the oil change interval varies between 9k and 10k mi. If you plan to keep the car for a few more years, I would change the coolant at 100k mi or every 4 yrs. Besides, you should replace the water pump, thermostat, coolant temperature sensor and the two radiator hoses at about 100k mi. The top radiator hose rarely lasts to 150k mi.
Old May 28, 2010 | 05:51 PM
RichardM98's Avatar
98 Brilliant Silver E320 Wagon
Obviously you've never had 30 yr old Scotch.
Old May 29, 2010 | 12:08 AM
werewolf34's Avatar
2009 E350 Sport
Macallans 18 is my choice; also Oban. 30 yrs you see declining returns
Old May 29, 2010 | 09:32 AM
SZMB's Avatar
2004 E500 CLK320
15 yr old coolant is good enough to drink as well.
Old May 29, 2010 | 10:55 PM
Dema's Avatar
i535
Never heard that people drink coolant, although it has some alcohol as I can guess. Mostly people drink brake fluid. Any way draining and replacing fluids recommended for any car. We do it for oil, but coolant.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
