Turn off rearview/sideview mirror autodimming?
Hello All,
Been lurking here for quite some time but was not able to figure this one out. I was wondering if it was possible to turn off the auto dimming feature on both my rear view as well as my side view mirrors. I recently had my windows lightly tinted and when the auto dimmer kicks it it can be somewhat difficult to see out of the mirrors. Any ideas? |
Cover the electric eye in the center windshield rearview mirror with a small piece of opaque tape. (Black electrical tape cut into a crisp small square is easy & unobtrusive).
Not 100% sure that this will work, but the mirror in my '07 has two connectors going to the dome assembly. One should be for the Homelink unit in the mirror, and the other should be for the auto-dimming mirror itself. I assume its a matter of trying to see if disconnecting either will disable the autodimming mirror yet keep the Homelink.
Do a search for "dome removal," and you'll get DIY instructions for removing the front dome lights to get to the mirror. They're pretty straightforward, and I got into my dome to replace a blown bulb within 30 minutes - just be careful of everything snapping into place. |
Originally Posted by Barry45RPM
(Post 4295173)
Thanks for all the tips. I was hoping that I could simply just switch the feature off. I may just go with a piece of tape. We'll see.
Thanks |
Originally Posted by doubleagle
(Post 4301351)
Thanks |
Originally Posted by lkchris
(Post 4304156)
When it's a safety feature, there's seldom a "switch to turn it off."
Originally Posted by PHDZINE
(Post 4305672)
...you can turn off traction control.
I was thinking the exact same thing. To me it seems as though the auto-dimming is more of a "comfort" type feature. But the ESP button is most assuredly a safety feature that can be disabled. |
(Post 4307940)
(Post 4305672)
(Post 4309171)
Not completely, actually. But, enough to get you out if you're stuck in snow.
Old thread but where exactly is the sensor in/on the mirror?
This car is new to me but I still can't figure out where the sensors are. I noticed that there is two humps on the top of the mirror that have slots on three of fourth sides and assumed that was them. After covering them with electrical tape I can confirm that is definitely not the sensors. I really only have one negative comment about the car, and the auto tinted mirrors is it. Where are the sensors!?
2 Attachment(s)
No mention of model year, hopefully attachments will answer your question.
Thanks for another informative and educational post, konigstiger.
I've found that the mirrors are woefully dim while backing at night, and if I have read the function correctly the reverse gear being engaged should automatically cause the mirrors to go to full bright thanks to the signal being sent to the appropriate module via CAN. Is there a way to test this function for correct operation? Would it be easier to simply install a brighter (LED?) reverse lamp in lieu of the incandescent ones already there? |
IMHO short of MB DAS doubt reverse gear CAN transmission, interpreted through overhead control panel, relayed to inside rearview mirror can be tested manually.
