2008 E550 Service D
How much are you paying for this service?
I did a quick search/google and didn't find it. |
It should be about 4 hours labor plus parts. D does not refer to specific service, just the time it will take to complete. Look at Maintenance Manual to find specific services involved
My Service D, on my '08 E63 was around $400... Oil change, cabin filters replaced and brake fluid flush/replacement.
Originally Posted by IndiumGreyE63
(Post 4320221)
beautiful car btw |
My service D cost $900...Power steering fluid, brake fluid and transmission fluid change.
Originally Posted by PHDZINE
(Post 4321167)
there is a sheet you can find on this site that shows you whats due at that milage and years. So two people could have "Service D" and require different items.
I go by the official service sheet and not by the alphabet soup. |
I called the dealer to schedule an appt and see what would be done. At 23k miles its and oil change and inspection. $370.00
Its miles *and* years .. at 3yrs for example the pano roof has to be serviced (if you have it) .. etc.
Originally Posted by Greg_S
(Post 4320238)
beautiful car btw
My car is also due for service D in about 9K miles. I just checked the FSS and it looks like these are the items that is needed for my car (yours could be different though) :
1 Due when displayed Check brake pads & rotors front/rear 2 Every 60,000 miles or 4 years Replace air cleaner insert 4 Every 30,000 miles or 2 years Replace dust filter 9 Every 2 years Check bodywork for paint damage Check chassis and load-bearing body components Replace brake fluid, check pressure of reservoir 10 Every 3 years Clean slide rails and shoes to sliding/pop-up roof 12 Due when displayed Engine oil and filter change 13 Due when displayed Check fluid levels, correct/repair if necessary • Brake system • Power steering • Windshield washer system Check safety catch and hinges on engine hood Check auxiliary battery condition Function check • Warning/indicator lamps, illumination and interior lighting • Windshield wipers, washer system, headlamp cleaning system Inspect tires Check thickness of front brake pads Check main battery. |
FWIW since it was only an oil change and 'checking' things I went to my mechanic that does all my other personal/work vehicles and had it done for about $136.00. Just couldn't pay $370+ for an oil change and there is no way they spend 2 additional hours looking around a car with 23k miles still in warranty
Originally Posted by wampa
(Post 4322303)
9 Every 2 years
Check bodywork for paint damage .... |
I could be wrong but my manual doesn't list service D. Comes up on dash Service D in 25 days. Still don't know what service D is.:confused: Does it cover all the numbered services as mentioned above or basically oil and filter changes?
