E-Class (W211) 2003-2009
7G-tronic transmissions now - sucks for us
Old May 22, 2003 | 10:06 PM
schvetkaaks's Avatar
Starting in the fall, our E class (among others in the lineup) will be getting 7G-tronic tranmissions, which improve fuel economy and acceleration. Those of us already with our 5-speed transmissions are stuck with them.
Crap.
http://www.imakenews.com/autospies/e...e000153302.cfm
(from autospies)
Old May 22, 2003 | 10:19 PM
RedBaron's Avatar
Re: 7G-tronic transmissions now - sucks for us
Originally posted by schvetkaaks
Crap.
Dude, this seems pretty low on the list of things to get disappointed about. Enjoy your car, it's one of the best around regardless of how many gears it has!!!
Old May 22, 2003 | 10:32 PM
nyca's Avatar
If I had an E500, I'd rather have the 5 speed, these transmissions are so complicated, I'd rather have a proven box then a brand new one they were working the bugs out of.
Old May 22, 2003 | 11:11 PM
Yeah, that's true - all I need is ANOTHER bug to work out on this car. God knows I have enough as it is!
Old May 23, 2003 | 07:38 AM
drb's Avatar
drb
03 E320, sport package, moon roof, sound upgrade, brilliant silver, charcoal leather, heated seats..
schvetkaaks
Why do you say you are stuck? Did you forget you can sell your car, and buy the 7G model?
Old May 23, 2003 | 08:56 AM
skymast's Avatar
2013 G550
Sounds nice but I would not want to be the lab rat.
I am not doubting the credibility of the article but I dont understand why my issue of AutoSpies (same Volume, Date, etc) did not have this article. Very strange.
Old May 23, 2003 | 09:23 AM
mco's Avatar
mco
ML430, E500
If you look at the german car fans website. this has been officially announced by Mercedes. It is not a rumour at at this point.
Old May 26, 2003 | 03:47 AM
northbenz's Avatar
sl and M-class E320 4Matic SLK350
Yeah, it is in a current issue of Autoweek as well. The only thing ambiguous is just when the E500 will get the 7 speed. Sounds like the E is down line and there is some reference to the 7 being added across the board once supply is available.
It would be really interesting to know if this slight improvement in fuel economy will be enough to get the gas guzzler tax dropped on all of the 500 engines, whether in the SL, S, or E. If so that would be a real impetus for getting it out sooner rather than later - especially with the current currency problems and exchange rate fluctuations making exported vehicles from Germany less profitable for Daimler Chrysler.
Old May 26, 2003 | 04:37 AM
mbprince's Avatar
one of seven
we'll all know soon enough when the E will get the 7G, and I for one wouldn't want one from the first 3 months of the production run. I'm picking up my new 03 E500/Sport on Thursday and at least I feel most of the first year bugs have been smoothed over. I plan to drive it till the dust settles on the 04 and when the forum is convinced that the 7G, the NAV and the voice command are all working, I am ordering an 04.....if the bugs get worked out in time........or an 05. And if the 7G does get the E500 out of gas guzzler range, I'm sure it will be offset by a modest overall price increase. So....enjoy!!!
Old May 26, 2003 | 03:43 PM
Otto's Avatar
W211 & Q7
enjoy your car
7 gears or 5 gears does not matter -- my wife knows nothing about it. especially it is automatic. (actually, 2 gears for her, accelerator and brake. )
Old May 26, 2003 | 04:04 PM
kaneman's Avatar
A brand spankin' new fresh design tranny scares me more than a brand new engine. There's a HELL of a lot more to go wrong with a transmission and they're a hell of a lot harder to put right than an engine if they do break. Let someone else be the labrat and be glad you got a 5 speed! Hopefully these won't be a complete disaster, but I'm sure they'll have their teething problems.
Old May 27, 2003 | 01:57 AM
Dema's Avatar
i535
I believe 7 speeds is optional, so you still can select 5 speeds for your new car. I think 7 speeds is a marketing trick. Cadillac still uses 4 speeds transmission and 87 octane engine showing better fuel economy at comparable HP.
Old May 27, 2003 | 09:07 AM
500AMG's Avatar
It's more than just gas mileage though. More gears should provide better use of the engine's power. It'll probably be a little quicker 0-60.
Old May 29, 2003 | 08:59 AM
Otto's Avatar
W211 & Q7
The new 7G-TRONIC seven-speed automatic transmission will be a standard feature
The new 7G-TRONIC seven-speed automatic transmission will be a standard feature of the E 500, S 430, S 500, CL 500 and SL 500 models from autumn 2003, replacing the five-speed automatic version currently fitted.
The newly developed seven-speed automatic transmission reduces fuel consumption in the NEDC driving cycle by as much as 0.6 litres per 100 kilometres (depending on the car), increases acceleration from 0 to 100 km/h by up to 0.3 seconds and allows significantly quicker intermediate sprints from 60 to 120 km/h.
Old Jun 10, 2003 | 12:32 AM
abhansali's Avatar
read the following:
http://www.imakenews.com/autospies/e...e000155697.cfm
Looks like 2004 E500 will have 7G for sure
Old Jun 10, 2003 | 04:22 AM
mbprince's Avatar
one of seven
same article from the source (MB) here .......
http://www.daimlerchrysler.com/index...3/t30514_e.htm
I am trying to find and will post another article I found mentioning the torque rating of this tranny and that later in the year a beefed up version would be built to handle the torque of the AMG and V12 engines. mp
Old Jun 10, 2003 | 05:08 AM
mbprince's Avatar
one of seven
here is the german version of the article I mentioned:
01.05.2003 7-Gang-Automatik ab Herbst 03 !
'Im Herbst 2003 feiert die neue Mercedes 7-Gangautomatik Weltpremiere. Vorerst wird sie in fünf Achtzylinder Modellen der E-, S-, CL- und SL-Klasse angeboten, da sie für 700 NM ausgelegt ist. Eine spätere Version soll dagegen 1200 NM aushalten. Dann wird sie auch in den V12 Modellen & im Maybach angeboten.
Ab Mai 2004 wird es die 7 Gangautomatik auch im brandneuen SLK (R171) geben.'
NM is the metric measurement for torque. this article says that the first version (fall 2003) of the 7G will handle 700NM which works for all the normal 5 liter V8s. It then says that in May of 2004 a 1200NM (high torque) version should be ready for release and that will be able to handle the power of the V12 and AMG engines.
We shall see
:o :p
Old Jun 10, 2003 | 09:12 AM
alewifebp's Avatar
2014 BMW 550i
Does anyone know how to translate the savings noted of 0.6 literes/100 kilometers in to miles per gallon?
Old Jun 10, 2003 | 10:46 AM
abhansali's Avatar
By my calculation (after doing some conversion), this means that the current 16/23mpg would increase to 16.7/24.4mpg. Calculation:
.6 litres / 100KM = .255g / 100 miles
If the car currently gives 23mpg, then it uses 4.348g to go 100miles. Now, it would use only 4.093g for the same 100miles, which translates to 24.4mpg. Did same calculation using 16mpg for city miles.
Question: would this be enough to avoid the Gas Guzzler tax?
Old Jun 10, 2003 | 12:14 PM
alewifebp's Avatar
2014 BMW 550i
Thanks for the info. I do hope that it avoids the gas guzzler tax, as that would save a decent bit of change on my lease (only $1000, but since that can't be residualized...)
Old Jun 16, 2003 | 10:33 AM
CLK430_ew's Avatar
clk430, e500
i just talk to people work in mb and he said 04 E500 don't have the 7g tronic transmissions for sure
Old Jun 16, 2003 | 01:54 PM
Mercedes101's Avatar
C240
Its ridiculous that you have to pay a Gas Guzzler Tax on a mass produced car like the E500. Then again its ridiculous that a $50K+ E320 has the same old low HP 3.2L 6. And its even further ridiculous that you can't get a NAV system on any of them.
Old Jun 16, 2003 | 02:16 PM
bmms8's Avatar
MB
well, the e500 tax isnt based on how many cars they make, its based on tge milage it gets, also, the 320 costs less than last years model, and has much more equipment, and safety wise ts better
Old Jun 17, 2003 | 05:43 PM
mbprince's Avatar
one of seven
on the DC website there is an article dated 5/14 from MB that the 7G will be on all '04 E500s. My dealer emailed me yesterday and said that production of '04 E's and AMG E55's will start first week in August and that command is set to go. I'm still waiting for him to get info on Nav.
Old Jun 18, 2003 | 12:58 AM
HizzleDizzle's Avatar
2004 E500
nice
I like to hear that your dealer said they will begin building soon for the 04 E's since my dealer says that mine should get here in mid to late Aug. since its the FIRST 04 E 500 to be ordered from the dealership. I hope it gets here around that time. and the 7G tranny would be a plus but i dont really care much bout it.
