E-Class (W211) 2003-2009
HELP!!! STUCK REMOVING STEERING ANGLE SENSOR
Old Oct 8, 2011 | 02:58 PM
dinodinoman's Avatar
2007 W211
Hi, All,
I'm completely stuck trying to replace the steering angle sensor on my 2007 E350 4Matic. I have removed the steering wheel, but the steering angle sensor itself has a long stepped sort of plug/prongs at the bottom, which go into the column. I've removed all the Torx screws for the black disc mechanism which is underneath the SAS, but it won't budge. I am stuck now, as I can't remove and replace the old SAS.
What am I doing wrong? Take a look at the picture below to see what I'm talking about. All I want to do is replace the SAS.
Thanks!
http://www.freeimagehosting.net/03977
Old Oct 8, 2011 | 10:08 PM
MercFiveHundred's Avatar
2014 E550; 2003 E500
In my 2003 e500, the clockspring looks different. The top part has three holes and spins to show three screws to remove. Once i remove those screws, the whole thing should pull/pry out gently with a flat screw driver from behind. Focus on the prongs and apply gentle pressure there.
