KEYLESS GO broken wire DIY
W211 2004 E500
Keyless Go not staring with button No error messages un dashboard Was thinking shifting knob is bad,but find out is BROKEN WIRE! There is step by step instructions how fixit I take pictures when i put together everything And then REVERSED them Click on images to enlarge them http://s8.postimage.org/c6p4kt5up/IMG_0114.jpghttps://s9.postimage.org/ms1a2j17v/IMG_0113.jpghttps://s9.postimage.org/frr2ez3l7/IMG_0112.jpghttp://s10.postimage.org/ye5mua551/IMG_0093.jpg if you want to take everything apart do next http://s12.postimage.org/e7zfaosd5/IMG_0111.jpg connect wires back,start the car shift in N or D and take out ashtray holder. Shift back in P and maybe disconnect rear battery. http://s8.postimage.org/njbvkd3oh/IMG_0110.jpghttp://s10.postimage.org/bgs1w9pqd/IMG_0109.jpghttps://s7.postimage.org/t44knqfpz/IMG_0106.jpg lift up console remove those plastic things and lift that wire to right side of shifter now you can put console on passenger side floor http://s12.postimage.org/cmoqwm7ix/IMG_0104.jpg http://s10.postimage.org/q91d1cl1h/IMG_0103.jpghttps://s7.postimage.org/475skkglz/IMG_0102.jpg raise up shifter slowly and take off that ring http://s8.postimage.org/igqev7ly9/IMG_0100.jpghttp://s8.postimage.org/wfiitxlup/IMG_0099.jpghttp://s12.postimage.org/mul2e8xw9/IMG_0097.jpghttps://s9.postimage.org/gr8n2kkx7/IMG_0098.jpghttp://s11.postimage.org/d3bsojr0v/IMG_0093.jpghttp://s11.postimage.org/8k45gryj3/IMG_0092.jpg http://s8.postimage.org/ipt1i9529/IMG_0094.jpg https://s9.postimage.org/6k4cerjsb/IMG_0095.jpg Now the HARDEST part those two wires are really short and hard to clean and solder DONT HOLD HEAT FOR TO LONG you can melt isolation https://s9.postimage.org/cb3pjz6jv/IMG_0096.jpg Thats how it look when i solder and put tape on. Let the wire go on right side on shifter Good luck and sorry about my english. Please let me know which site i can use to post bigger pictures for free. |
Terrific writeup....thanks. Clicking on a pic brings it up full size btw.
Glad I bookmarked this post, because it looks like I may have this same broken wire, based on my KG symptoms. The op may only have 2 posts , but this one is a winner. Thankfully, all the pics are still up.
Edit: sure enough, my wire is toast. Edit#2: The only thing the op didn't mention is that 2 black screws, holding the side panels in place, require a T-10 Torx driver and the silver screws holding the console, are T-27. I was able to remove the ashtray holder without having to shift the gear out of park. The plastic tabs on the shifter housing were difficult to break loose. Screwdriver didn't do it. I had to use a wider and flatter blade and hit it with a small hammer to break loose on both sides. When removing the shifter assembly from the tranny connecting rod, stuff a towel into the hole so the grommet and/or the snap ring don't fall into the hole and then to the ground. I had to retrieve both of them a couple of times. Oh, and I did disconnect the battery after everything was apart. Lastly, to solder the wires, they were too short on the shifter side to do any twisting so I "tinned" all 4 ends and then just held them in an overlap position to re melt the solder on each connection. Use a very thin iron tip. I used a Weller soldering station PTL tip.(Click here) Other than that, it went smoothly, no other surprises. |
Thank you
Thanks for your thread.
But picture too small. Could you letme see bigger pictures please? |
Nice job!!!
Originally Posted by suphinx
(Post 5650358)
But picture too small. Could you let me see bigger pictures please? |
Outstanding writeup! This thread is a gem, you just saved me $1153.95 :y
Have you found the broken wire ? And, if so, what were your keyless go problems/symptoms
Edit: thanks for the pm's |
Excellent..
Fantastic post thanks It will help lot of members
Thanks for this. Just did this repair today and it seems to be working. Man those wires are thin, soldering them was a real pain in the ass and i was sure i didn't do a good job but it seems to be working.
Instead of soldering, consider using "electrical lever nuts" available in 2-conductor to 5-conductor and work with 28 gauge to 12 gauge wire:
Nope, won't work. The wires aren't long enough for all to connect from the same side like that. They barely overlap ~1/4 in as it is.
Also, keep in mind that the wire moves with the shifter and the connector may get hung up. Good thought though. |
Fantastic post Huligan. I just had my armrest disassembled today because I face the exact same problem. But when I got to the shifter assy I became unsure, and backed out of it.
But now when I have read your post, I will check this tomorrow.... Great pic's :y Best regards, Michael |
hello... does anybody have the manual configuration of they keyless go for a E320 2003? doors not working...thanks...
Is there a place that these pictures are posted larger? They don't expand to full screen anymore.
No, but I have most of them from the original post, and will try to post them over the weekend.
Originally Posted by starbrite
(Post 6660866)
10 Attachment(s)
Ok. here they are.....all that I have, however, I think there's only a few missing: (start with the last pic in the second post)
Left clicking on a photo will start the slide show. If you want to view a photo even larger (before the slide show), right click on it and then select "Open link in new tab" or in "new window'. Either one works both in IE and Firefox. |
6 Attachment(s)
The rest.... (these are not in order)
Thanks sir!
Just fixed mine, works perfect now!
So what other symptoms did you guys have? I'm going to check my wire out this week, but I'm having no messages about key in the dash. Push to start doesn't work. And all the doors unlock and lock barely work. Rare time it may work.
Note that the op states "No error messages un dashboard "
Push to start is independent of the doors and trunk. Most likely your wire is broken. |
Only if no error message
Originally Posted by Huligan
(Post 4933226)
W211 2004 E500
Keyless Go not staring with button No error messages un dashboard Was thinking shifting knob is bad,but find out is BROKEN WIRE! There is step by step instructions how fixit I take pictures when i put together everything And then REVERSED them Click on images to enlarge them http://s8.postimage.org/c6p4kt5up/IMG_0114.jpg https://s9.postimage.org/ms1a2j17v/IMG_0113.jpg https://s9.postimage.org/frr2ez3l7/IMG_0112.jpg http://s10.postimage.org/ye5mua551/IMG_0093.jpg if you want to take everything apart do next http://s12.postimage.org/e7zfaosd5/IMG_0111.jpg connect wires back,start the car shift in N or D and take out ashtray holder. Shift back in P and maybe disconnect rear battery. http://s8.postimage.org/njbvkd3oh/IMG_0110.jpg http://s10.postimage.org/bgs1w9pqd/IMG_0109.jpg https://s7.postimage.org/t44knqfpz/IMG_0106.jpg lift up console remove those plastic things and lift that wire to right side of shifter now you can put console on passenger side floor http://s12.postimage.org/cmoqwm7ix/IMG_0104.jpg http://s10.postimage.org/q91d1cl1h/IMG_0103.jpg https://s7.postimage.org/475skkglz/IMG_0102.jpg raise up shifter slowly and take off that ring http://s8.postimage.org/igqev7ly9/IMG_0100.jpg http://s8.postimage.org/wfiitxlup/IMG_0099.jpg http://s12.postimage.org/mul2e8xw9/IMG_0097.jpg https://s9.postimage.org/gr8n2kkx7/IMG_0098.jpg http://s11.postimage.org/d3bsojr0v/IMG_0093.jpg http://s11.postimage.org/8k45gryj3/IMG_0092.jpg http://s8.postimage.org/ipt1i9529/IMG_0094.jpg https://s9.postimage.org/6k4cerjsb/IMG_0095.jpg Now the HARDEST part those two wires are really short and hard to clean and solder DONT HOLD HEAT FOR TO LONG you can melt isolation https://s9.postimage.org/cb3pjz6jv/IMG_0096.jpg Thats how it look when i solder and put tape on. Let the wire go on right side on shifter Good luck and sorry about my english. Please let me know which site i can use to post bigger pictures for free. Just quickly quistion never find why mine isn't working had other more important stuff to fix first but time came it is not working but getting the error on display "Key Not Reconized" Did I just get the wrong key NONE keyless or any other ideas anything. Also cross checked all doors none will unlock keyless.. Betting key need new one and need recode ? |
