E-Class (W211) 2003-2009
Panoramic roof
Old Jun 18, 2003 | 08:49 AM
psyrtash's Avatar
Panoramic roof
I have front and rear solar panels in my roof. Now that we have warmer weather I was hoping to observe some difference in cabin temperature when the car is parked in the sun.
Unfortunately I am not able to notice any difference.
Does anybody have the same experience?
E320,Parktronic,Electr.Panorama,Solar Panel,Multi-Contoured,
Rear Shade,By-Xenon Headlamps,Harman Kardon,Climate Comfort,4 way H/Air.
Old Jun 18, 2003 | 03:54 PM
northbenz's Avatar
sl and M-class E320 4Matic SLK350
What does the dealer say? Perhaps your unit isn't operating properly.
Old Jun 18, 2003 | 05:21 PM
BMcD-E500's Avatar
2013 GL550
My understanding is that they only kick on the fans when the inside of the car reaches 86 degrees. When you get in you should feel a small amount of air coming from the vents in the dash. If you park in the sun, close the roof shades and rear/side shades if you have them. Keep in mind it's only blowing the outside air around, it's not running the AC. Hope that helps!
Bruce
Old Jun 18, 2003 | 08:54 PM
cmaustin's Avatar
I noticed it working for the first time the other day. It probably was working before, but I did not hear it. After your car has been in the sun for awhile, just get in and close the door. You can hear a fait fan noise and light air blowing from the vents.
I think it works fine. The inside of a car will go to about 120 degrees without ventilation in about an hour. With the panels, the inside of you car will only rise to the outside temp. Much better than 120.
If you get in your car on a day greater than 80 degrees and the inside of your car is not on fire, you can thank the solar panels. The air also doesn't smell "stale" because of the circulation.
Old Jun 18, 2003 | 10:33 PM
E500Lorinser's Avatar
I didnt get the Pano cause I didn't think it would look good on white(now I have seen a few and I like the look).If I read correctly there is no open sunrooof just 2 glass panels?If so then I don't feel as bad I like the open air of a regular sunroof,correct me if I'm wrong and there is a sunroof.....
Old Jun 18, 2003 | 10:46 PM
rickyfanmdr's Avatar
2003 E320
E500Lorinser, the front panel operates as a normal opening sunroof, and the back panel is fixed and can't be opened. When you open the front panel, it stacks on top of the back panel (lifts up then back). I got the silver because I didn't think the pano would look good with white. While I'm very happy with my choice, I have now seen the pano with white and think it's very pretty too.
Old Jun 18, 2003 | 11:01 PM
rickyfan
Thanks for the info,now I feel bad again LOL I thought it looked so good on black and silver,and would look weird on white.Now after seeing one on the road,and pics on this website,Im in agreement with you.With tint its actually pretty hot,oh well...................
Old Jun 19, 2003 | 08:31 AM
marc777's Avatar
2012 CLS
I have a pano roof on my silver E. Its cool.
But I have noticed that at the rear of the car the roof makes a noise when going over slightly uneven surfaces - especially at low speeds - it sounds like the roof is flexing.
Has anyone else found this?
Marc
Old Jun 19, 2003 | 09:59 AM
rayscar's Avatar
2003 MB E500
Marc
No such noise on mine.
Old Jun 19, 2003 | 10:03 AM
sf49ers79's Avatar
Honda Accord EX V6
no such noise on mine, too
Old Jun 19, 2003 | 10:23 AM
psyrtash's Avatar
Marc
Yes . I have the same problem, but it only sounds like its coming from the roof.There is a lot of plastic in the car and when they start flexing you get these sounds. On of these problems was traced to the back of the passenger head rest.
Old Jun 20, 2003 | 01:18 AM
2003 E320
no such noise on mine, either
Old Jun 20, 2003 | 11:16 AM
KevinR's Avatar
No noise here.
Old Jun 20, 2003 | 11:32 AM
DKSNY's Avatar
BMW 330CIC
Kevin,
When was the build date on you car?
Old Jun 20, 2003 | 05:11 PM
psyrtash's Avatar
Originally posted by DKSNY
Kevin,
Sept 2002
Old Jun 20, 2003 | 11:07 PM
feo2's Avatar
Mine does this. Happens every time I turn into the underground parking garage at work. Just as the car crosses the sidewalk/curb and then quickly descends into the garage. Very obvious flexing going on.
Old Jun 21, 2003 | 04:43 AM
KevinR's Avatar
Kevin,
DKSNY,
April 2003
Old Jun 23, 2003 | 12:00 PM
inkm's Avatar
E500 SPORT
I have the same problem when going over slightly uneven surface. Anybody fixed this problem? please let me know.
Old Jun 23, 2003 | 10:03 PM
DKSNY's Avatar
BMW 330CIC
Originally posted by KevinR
DKSNY,
April 2003
thanks Kevin
