MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   E-Class (W211) (https://mbworld.org/forums/e-class-w211-20/)
-   -   Driver's seat controls problem - Please, help to diagnose (2004 E320) (https://mbworld.org/forums/e-class-w211/431200-drivers-seat-controls-problem-please-help-diagnose-2004-e320.html)
emzet Jan 16, 2012 09:30 PM
I have my driver's seat controls working only partially on my E320 (W211 - 2004 E320 with dynamic/vented seats option). The back rest works only one way (reclining) and the head rest does not move at all. The seat still moves back/ forward/up and down.
Can anyone suggest a good way of diagnosing whether it is the control module that is failing? Which control module would this be? I understand there are two of them one under the seat and another one behind the door panel.
Any help greatly appreciated.
emzet Jan 17, 2012 02:45 PM
I had a mechanic checking the seat controls last night. He was not able to identify what the problem was. The only thing he did was what I specifically asked him not to do - that is while testing it, he moved the back rest back a little more!....
I am running out of pillows to put behind my back to be able to drive my car ;)
Is there by any chance a way to manually adjust the back rest back up before I am able to sort this out?
emzet Jan 27, 2012 10:03 PM
Quick update: the problem fixed.
I have purchased the 2004 Mercedes Benz E320 W211 Left front seat module P# A2118201185.
The replacement of the unit (it is the one located under the seat) took about 10 minutes.
The seat controls are back to normal. Thanks
cjdfarmer Jan 30, 2015 07:47 AM
I am going to replace mine over the weekend. I tried the switch first - it did not fix the problem. I have ordered a control module and it is coming today. Any advice on how to do the job, in the ten minutes it took you sounds great, would be appreciated! 2004 E500 Wagon
ptkacik Feb 1, 2015 12:17 PM
So how much does a seat module cost?
zafarmd Feb 1, 2015 12:43 PM
I have a similar problem on my CLK W208 the seat goes forward only but try using the pre programmed buttons 1,2,0r 3 if these work you are in good shape , mine still work normal .Good luck
konigstiger Feb 1, 2015 02:54 PM
MY05 e320cdi left seat: 2118201185, 2118208585, 2118700526, 2118704926, 2118709926, 2118704085, or 2118704785. Quick search:
http://www.ebay.com/itm/03-06-MERCEDES-E320-E55-E500-LEFT-FRONT-SEAT-CONTROL-MODULE-2118208585-OEM-/171659402660?pt=Motors_Car_Truck_Parts_Accessories&hash=item27f7b29da4&vxp=mtrhttp://www.ebay.com/itm/2005-2006-Mercedes-Benz-W211-W203-C230-Left-Seat-Control-Module-2118700526-/261451334364?pt=Motors_Car_Truck_Parts_Accessories&hash=item3cdfb6c2dc&vxp=mtr
© 2026 MH Sub I, LLC dba Internet Brands
