E-Class (W211) 2003-2009
headrest rattle
Old Jul 8, 2003 | 10:57 PM
wem's Avatar
wem
‘24 Maserati GranTurismo Trofeo;'22 AMG SL55;'23 Porsche Cayenne S Coupe;'13 Porsche Boxster S
headrest rattle
Has anyone else encountered headrests that rattle? The noise goes away if you lean your head on the headrest, but it's especially annoying when the passenger seat is unoccupied.
Old Jul 8, 2003 | 11:01 PM
bmms8's Avatar
MB
Re: headrest rattle
hmm, i think this is the first time i have seen this. i would just try to fix it by maybe pushing the front headrest in and out, if you look in the manual you'll see that you can adjust it, that might fix it, if not, im sure your dealer can get another one
Old Jul 9, 2003 | 03:17 AM
FJPM's Avatar
2003 E 500 - Full option
No rathling problem with passenger headrest but the back vibrates especially if wheels unbalanced.
Old Jul 9, 2003 | 07:49 AM
bmw2mb's Avatar
530
i had this too. i think it's the plastic ring cover around the bars connected to the seat. i shoved a tiny piece of cloth under the ring and the rattle went away. this was driving me crazy since my wheels will not balance propertly. the cars vibrates at 50 mph. i think i'm going to have to get differents tires to fix this.
Old Jul 9, 2003 | 10:31 AM
FJPM's Avatar
If you have Conti Sport Contact 2 (as I had), they become difficult to balance after 25000 km (15 000 miles). I changed it for Michelin Primacy at 30000 km.
Old Jul 9, 2003 | 10:44 AM
SDChargers's Avatar
MB E320, BMW 323i
wem,
You are not alone - I have the same passenger seat rattle problem as you described. Not to the point of annoying but noticeable. I'll try to live with it since it only appears on certain stretches of pavement and it's not intrusive.
Old Jul 9, 2003 | 12:30 PM
e500's Avatar
E500
wem,
I had the same issue w/the passenger seat head rest. The dealer replaced the motor and it's never rattled since.
Old Jul 9, 2003 | 12:47 PM
jazman's Avatar
E500
Headrest rattle
I have the same problem - especially at highway speeds when the passenger seat is unoccupied. I reach over and adjust the passenger headrest and it goes away. Until the next time I'm at highway speed... sigh.
Old Jul 9, 2003 | 01:56 PM
wem's Avatar
wem
Thank you everyone for the suggestions. The car is supposed to go back in on the 21st. I'll communicate the suggestions about the head rests.
Old Jul 10, 2003 | 12:17 AM
feo2's Avatar
Well, I've had my car in the shop for this problem 4 times. Started out by applying grease, then placed felt around the rods, then replaced the motor, then took the seat apart and put it back together.... Now they want to replace the structure in the seat. That is, of course, if the service advisor ever returns my call.
I've also got serious vibration in the shoulder belt adjusters on both sides. I was told, "that's the way they are designed. If we fix it they won't work properly".
Where's that MBUSA dealer satisfaction survey again....???
Old Jul 10, 2003 | 08:55 AM
FJPM's Avatar
I would try to chase the vibration where it is originated.
I suggest that you check the 4 wheels balance.
If you ned to rebalance shortly after, it means that you have to change tires.
Old Jul 10, 2003 | 12:17 PM
Juanjo's Avatar
'03 E320 CDI Avantgarde '00 Renault Mégane Coupé 1.6 16v (wife).
Familiar with that rattle. Almost unnoticeble (not to the point to bring the car to the dealer), but it is there when no passenger at low speeds. So you say a wheel balance problem. But wheels may be balanced, because no rattle in the steering wheel.
My car came whith the Conti SC 2.
Old Jul 10, 2003 | 09:22 PM
cmaustin's Avatar
I have the passenger seat head rest and plactic seat belt holder (top part next to your head) rattle. I mentioned the seat rattle and the service rep said "don't put it up so high". He was right in that it didn't rattle when the passenger headrest is up two inches or less. The seat belt rattle is pissing me off. I move it and is goes away but keeps coming back.
Old Jul 12, 2003 | 01:35 AM
vdimemmo's Avatar
This noise is driving me crazy!
I understand that its subtle, and that it may not be a big deal to others, but I almost hate driving the car alone anymore!
I drive 2 hrs each way to work. It's torture. I yell at it. I punch it. Soon it will be on the shoulder of the NJ turnpike.
The only good thing about it...its louder than the 'valve tap-like' noise coming from my moter mounts.
Old Jul 13, 2003 | 12:03 PM
pat a.'s Avatar
yes, i absolutely have that problem. It is worse as the headrest is extended out from the seat. Somewhat annoying.
Old Jul 13, 2003 | 06:58 PM
RJC's Avatar
RJC
Various
The backrest of the passenger seat of my clk 500 rattles when no one is in the seat...it was the same on my 99 00 and 01
Old Jul 13, 2003 | 11:07 PM
ICY's Avatar
ICY
i find the rear armrest rattles if I've got it down. the noise comes from the cupholders
having the armrest up solves the problem......anoying neverthless, esp when I carry passengers in the back and they like the armrest down
