New E500 Owner, want to do oil change, just want to confirm a few things
SubscribeHey guys,
I did some research, I'm going to buy a Mann oil filter and Mobil 1 0w-40 synthetic oil. I found two different Mann oil filters, can someone tell me which one I should buy?
Mann Paper Oil Filter - $5.94
http://www.rmeuropean.com/Part-Numbe..._8DF8FDD7.aspx
Mann Polyester Oil Filter - $11.47
Also, can someone tell me the correct oil filter cap socket to buy?
Thank you!
Thank you!
Buy the one which is made of polyester.
I can't help you with the socket size for the oil filter, I use a strap wrench. I think the size is stated somewhere in the DIY oil change thread in this sub-forum.
http://www.bmwmercedesparts.com
This is where I go to get all my parts. Genuine Mercedes polyester filter. Don't forget to replace copper washer as well. I never reuse mine.
Great! Thanks guys. So polyester filter and copper washer, does anyone know the part number for the copper washer?
Thanks!
Thanks!
Quote:
Thanks!
Originally Posted by Lefix
Great! Thanks guys. So polyester filter and copper washer, does anyone know the part number for the copper washer?Thanks!
Here is what I use from the link I posted above.
007603014106
Thanks Gersh320
Welcome
Get the oil good and hot, then take your time. It is a great opportunity to inspect the underside. I bond with my E quite a lot during this time
. I also like to let it drip for about 3 or more hours before putting new oil in.
