Everybody's Stumped
I have just purchased a '93 300e with a problem that no one seems to be able to solve. I have had the same mechanic for over 10 years and while he doesn't say he can't fix it, he has had the car for 4 days with no solution yet. I really trust this guy, but am getting desperate. Here's the problem:
The car starts fine, and can run a little rough at first but once warm seems to idle fine. When accelerating the car does fine until somewhere around 1500-2000rpm at which time the acceleration drops out. If I back off the pedal and slowly start pressing it again it will accelerate until the same rpm point and then stop accelerating. I have repeated this until I have the car up to 65 miles per hour at which time she seems to run fine. But if I come to a grade, (uphill), she slowly losses speed and won't accelerate until the road becomes level again, at which time she will SLOWLY regain her speed by not pressing too much on the gas. The previous owner alledgedly switched out the 'throttle body', and the 'computer' with no change, (the old ones were in the trunk when I purchased the vehicle, although I doubt new OEM parts were used as replacements). I figured the previous owner just didn't know what he was doing and was sure my mechanic would quickly diagnose and solve the problem, but so far no results. Before taking it in, I noticed the smell of gas as though the fuel mixture was too rich, also some VERY tiny black bits coming from the tail pipe. Car has no visible leaks WE ARE STUMPED! Has anyone ever encountered this problem?? Help!:wall: |
Your probably better served in the appropriate forum, this is for 03+ cars that don't even share the same engines or electronics.
Good luck |
Thanks, (new to this site)
Will do... so as I can find it!
Dirty Fuel Filter?
Try changing the fuel filter and see what happens. Had a similar problem many years ago with my girlfriends' grandmothers' powerglide equipped Chevy V8. Drove up nuts until we figured out it was a fuel starvation problem caused by the in-line fuel filter. Easy on the throttle, everything was fine, but give it too much throttle, and it would simply quit. 'Course that was with a carburator, so who knows? :confused: Good luck! :D DHG |
+1 for checking the fuel filter.... I had an 88 IROC that had the same issue.... it was the fuel filter. Also, check ignition system too. Plugs, wires, etc (which I'm sure your mechanic has done :nix:)
Originally Posted by Roggie
(Post 5444983)
The car starts fine, and can run a little rough at first but once warm seems to idle fine. When accelerating the car does fine until somewhere around 1500-2000rpm at which time the acceleration drops out. If I back off the pedal and slowly start pressing it again it will accelerate until the same rpm point and then stop accelerating. I have repeated this until I have the car up to 65 miles per hour at which time she seems to run fine. But if I come to a grade, (uphill), she slowly losses speed and won't accelerate until the road becomes level again, at which time she will SLOWLY regain her speed by not pressing too much on the gas. The previous owner alledgedly switched out the 'throttle body', and the 'computer' with no change, (the old ones were in the trunk when I purchased the vehicle, although I doubt new OEM parts were used as replacements). I figured the previous owner just didn't know what he was doing and was sure my mechanic would quickly diagnose and solve the problem, but so far no results. Before taking it in, I noticed the smell of gas as though the fuel mixture was too rich, also some VERY tiny black bits coming from the tail pipe. Car has no visible leaks WE ARE STUMPED! Has anyone ever encountered this problem?? Help!:wall: Steve |
| All times are GMT -4. The time now is 07:00 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
