Blower Fan Chirp fix/repair?
Is removal of the blower fan (and replacement) necessary or did some of you find that lubrication was sufficient to get rid of a chirp? For those that simply lubricated to resolve, what product did you use? thx ... for reference, I'm driving 2006 E350 4matic ... with a chirping blower motor
On my 2003 E500, I removed the footwell cover on the passenger side below the glove box to gain access to the blower motor housing. Then remove 4 screws on the housing and the motor comes out. I lubricated the bearings on both ends of the motor with electrical contact spray lubricant by CRC. It hasn't squeaked since then; it's been almost 2 years.
2006 E500
After I had removed the foot well trim and taking note of the exact location "under" the bearing, I drilled a very tiny hole in the trim. Every 6 months when it squeaked, a quick blast of WD40 or silicone spray using the tiny plastic tube fixed it instantly!
