My install of clear side marker lights...
The marker lights are in two pieces. When you get your aftermarket lense, squeeze the tabs together on back which you will see and pop the outer lense from its' plastic housing. Once I did this, I saw that I needed to do the same to remove the factory lense. The outer clear part installs from the outside and the black housing installed from inside the fender. They snapped together with the fender sandwiched in between. Hope this helps someone.
Thanks for the writeup.
thanks!
-M
Here's my recent post on this:
https://mbworld.org/forums/e-class-w...e-markers.html
