License Plate Light Replacment - LED - 2009 W211 **HELP**
I have watched and read pretty much EVERYTHING there is out there on replacing the license plate light fixture on the 2009 E350 [W211]
I am able to remove the panel and get to the fixture, but for the life of me am not able to remove it from its setting. It seems to me that the unit is too big to push down and out through the outside of the vehicle and I can't figure out how to pull it out from behind the trunk panel. I was able to separate it from being clipped in place, but just can't get it out. The new LED fixture also doesn't seem that it would enter through the outside, and I could only imagine it squeezing in from the inside, behind the trunk panel.
ANY help would be appreciated since I am at my wit's end with this DIY job. See below for the LED that am I trying to install. I am sure I am not the only one that has had this problem, and all of the threads I read seem to touch on 2010 W212 and forward or prior to the 2009. PLEASE HELP!!!!!!!!!
Which rear handle? The one used to open the latch from the outside? I have removed the panel from the inside and tried to remove it from the inside. The only thing I removed from the outside was the clear plastic cover to the license plate lights and removed the old bulb. I can figure how to remove the entire fixture to then insert the fixture I showed above. Please assist!
Ok, First open the trunk lid---do you see the license plate bulbs---then do you see two screws between the bulbs. Those screws hold the handle in place----if the screws and handle are not there then I am looking a the wrong document???
If they are there then do as I suggested
ok - so I figured it out, finally! You MUST remove the lower 1/2 panel on the outide of the trunk. There is a screw on either side behind the trunk panel and you must also remove the license plate covers/plates. There is also a central screw from behind the trunk through the center of license plate.
Here is the tricky part - You then have to start on either end and CAREFULLY pull the panel toward you while sliding your finger or plastic tool towards the center of the panel to loosen the clips holding it in place. I believe there were 4 or 6 total. The lower half of the trunk then slides down and the whole light fixture comes off. Insert the LED fixture, test and then reattach the panel.
Good luck - I wish I took pictures, but I was so excited to finally get it on after wasting so much time.
PS - the LED license plate lights look great - I am thinnking about converting every single bulb now.
cMazara (07-21-2017)
UPDATE: I did the same installation today. The OP forgot to mention there are 3 clips on the bottom half of the panel and glue so you need to slide a flathead from one side all the way across the bottom to the other side to undo the bottom clips and glue. At this point you can pull the panel! I can understand why the OP didn't include pictures of removing the panel because after all this I was SO happy to finally have that **** off!!!
14 550 sedan
For some reason just an LED bulb swap did not work for me.. The housing that held the bulb deflected too much light and it would appear very dim, even with the brightest most expensive bulb I could get my hands on.
Lasted like an hour searching, this is the ONLY thing that helped me continue.. dam this germans, had to dismantle half of the trunk to change 2 bulbs.. Leds look amaizing. wished i had done a diy but it was 2am and really pissed as how hard is to changed this.
Yep, see this thread.
http://www.benzworld.org/forums/w211...te-lights.html
Shows how to remove the rear panel. Super easy but not as intuitive if ya never did it before.
Total time to remove lower panel and trunk liner is about 15-20 minutes.
-Nigel
-Nigel
-Nigel
-Nigel
