E-Class (W211) 2003-2009
Anyone transported 4 wheels with tires in their car?
Old Jun 9, 2013 | 01:40 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
I'm going to go buy a set of used wheels with tires and was wondering if anyone had tried fitting four in their car (2 in the trunk, 2 in the back seat). These are just standard 17" 7.5 wheels.
Old Jun 9, 2013 | 01:57 PM
illest's Avatar
w210 AMG or S213
It will work I think. I carried 4 18x8.5 only one would fit in the trunk.
Old Jun 9, 2013 | 09:12 PM
AMGAffalterbach's Avatar
2014 BMW M235i
Yes I fit all four of the OEM 18" in my car with tires on them (they were 40 series tires I believe). I had one in the trunk, then two behind each front seat that wedged one on the center seat in the back. Make sure you have them in bags or bring along some towels for padding, just be careful that with that configuration - the only way it will really fit - you can't make any sudden stops or the wheel will fly into the back of your seat and it will hurt
Old Jun 9, 2013 | 09:17 PM
DubVBenz's Avatar
That's what I ended up doing. A shame I couldn't get two in the trunk.
Old Jun 10, 2013 | 02:14 AM
cc260E's Avatar
E420CDI 2008, GLK220CDI 2009
Yes it works . I did with 245/45/17 wheels. the one in the back seat are just little wide for the doors but it is ok.
May be you can put three of them in the trunck. with unflated tires it is mor easy. then you inflate them after transportation
Old Jun 10, 2013 | 02:41 AM
2014 BMW M235i
You can't fit three wheels (18s that is) in the trunk only 2. With tires only one as DubVBenz said. You might be able to with 17s but only if you don't have tires on them.
Old Jun 10, 2013 | 06:36 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
I fit two in the trunk and two in the back seat. I also have a 12" JL sub in the trunk. My wheels are 18" though.
Old Jun 10, 2013 | 08:59 AM
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
I just moved 4 18" wheels with tires. Fortunately, i have the fold down rear seats.
Old Jun 10, 2013 | 01:33 PM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
When I go to the track, I fit one in the trunk, one behind the driver seat and two behind the passenger seat. I use the child seat hard points to keep the tires tied down.
I use an old sheet to protect everything inside the car.
Old Jun 10, 2013 | 11:40 PM
2014 BMW M235i
Well I usually just buy a G63 AMG every time and haul them around that way.
