E-Class (W211) 2003-2009
Not the Crankshaft Position Sensor...
Old Jun 18, 2013 | 01:12 PM
dtt2004e320's Avatar
2004 E320
Went to go to work this morning and got crank but no start on my 2004 e320. Read the threads about the CPS and replaced it but no go. all my topic searches result in the CPS... thoughts on next steps? No codes on the reader either.
Old Jun 18, 2013 | 02:35 PM
jagata's Avatar
S6 LP640 E500
Same thing happened to me also, but mine started again the morning after I replaced the CPS but did'nt start imediately after replacement.
Maybe a blocked fuel line, thus no error codes.
Old Jun 18, 2013 | 02:38 PM
2004 E320
Thanks. Can you point me to fuel diagnosis steps? First time working with this car...
Old Jun 19, 2013 | 05:40 PM
jagata's Avatar
S6 LP640 E500
I don't know, that's beyond my scope of experience. I would think a shop would check for fuel pressure with some gauge connected to the line.
Old Jun 19, 2013 | 05:44 PM
RobertG's Avatar
things with and without wheels
when you turn the key on do you hear the fuel pump run?
Old Jun 19, 2013 | 08:55 PM
PepperE500's Avatar
2003 W211 E500
I had a similar issue with my 03 E500 last month. It was the cam position sensor. Wouldn't let the car start on hot starts. It would crank but not turn over. Hope that helps!
