E-Class (W211) 2003-2009
2009 E350 Lower beam headlight bulb replacement
Old Oct 16, 2013 | 04:18 PM
JaneJ's Avatar
2009 E350
Hi all,
My 2009 E350 had a light bulb burnt out. It is the one in the round socket on the driver's side. I did some research online and bought an H7 light bulb. Then I realized that the instruction I watched are for the one that is more towards the center, located in the same housing as another one with blue tip. I am not sure how to describe the one I need to replace. It is in a tight corner. I was able to remove the cap by twist it the same way as the other one. But I could not get the plug out by twisting and pull like the center one. Does anyone know what the name of this light is? Does it also take a H7 bulb. I can't see through the lens of this one. Can I replace it myself?
Thanks a lot for your help,
Jane
