Throttle Housing replacement
Hey everyone:
I need to change the throttle body on my 05 w211. Needed confirmation advice on location. I'm thinking I have to remove the the intake manifold cover where the MAF is going into, there is like six torx scews and a couple of reverse torx screws holding in place. Would this be right? thanks in advance! |
don't remember any torx screws....just a bracket that goes around the MAF that you can just undue with a flat head. also, remove the hose at the bottom, then just pull.
