Turn Signal Flasher Relay
I'm trying to replace it with one from here
http://www.superbrightleds.com/cat/led-vehicle-replacement-bulbs/vehicle/2008-mercedes%20benz-e%20class-with%20halogen%20capsule%20headlamps-installation+accessories/37-464-50-528376/
So that I can use LEDs without having to add resistors.
Thanks!
I am also looking to the LED flasher relay on my car and cannot find it, however my car is a 2010 GLK350 4matic. The Flasher started working and not working and flickering for some time and now it doesn't work. I took the cover off and tested it with 12 volts. it works. so the LED are good. I can't locate the Relay which sounds to be the problem. If anyone knows where I can find it or which one it is. That would be great.
Lots of shared parts and technology.
As an example, so all discussion of some particular aspect of the M642 engine would be in one thread no matter which car it was in, while all discussion of some particular suspension issue would be similarly grouped.
When the hell is Artificial Intelligence actually going to do something useful like that?
