2003 E320 squeaky noise over bumps!
When i go over bumps or potholes at speed more than 20mph i get high pitch short squeaky noise. What could it be? im pretty sure it's not the springs.. :confused::confused::confused:
Dry or worn ball joints can make noise like that. Also, failed strut mounts (on top) can make noise.
Originally Posted by bernard farquar
(Post 6022306)
Ball joints
Inspected the car.. Needs new ball joints both side $310 total cost. Seems alright?
Originally Posted by despicable merc
(Post 6023979)
2 types replace arm and bolt in w/3 bolts, Make sure you know what you have. |
Originally Posted by vettdvr
(Post 6024209)
Yup! about right!
There is a early model E with top ball joint mate into the Control arm. The upgrade arm has the ball joint installed with 3 bolts and the arm doesn't have to be removed.
I believe vettdvr is talking about the upper ball joints. I did not see where you said either top or bottom ones. The bottom ones just press in. The squeaky ones on my car were the bottom ones.
Replaced joint balls no more squeaking!
Repair cost $280 |
(Post 6028235)
Repair cost $280 |
Originally Posted by mingamells
(Post 6042258)
That seems cheap. Did you do it yourself or have a shop do it? Thanks.
