E-Class (W211) 2003-2009
Strange audible alarm/chime Sound
Old May 19, 2014 | 08:19 PM
GT854T5's Avatar
2005-W211 designo Estate
Hello all- I've been a member/lurker-ha,ha,ha- for a few months. I have learned A LOT from the forums, so thanks guys/gals. I have searched for help on this issue to no avail: I have a 05 4matic 500 wagon; recently i have heard a "weird" alarm/chime while driving. Out of the blues, an alarm sound that lasts about 1-3 seconds. It is a fairly high pitched chime. NO messages show on the info cluster. It is NOT the seatbelt chime, since we were belted. Not the parking brake, cause I get a big-red reminder in dash. It has happend about 4-5 times in the past few months. I can't record it, since it happens without warnings. When it occurs: it has only happened in day time; I believe my sunroof had been opened (in tilt positon); happens when I have a passenger in front seat; AC/Heater is off; radio/CD was playing; it has happended 2x while driving(50-60mph) and 2x as i started to drive off from stand-still.
Any ideas on what is the cause, and how to reslove??
P.S- I have Keyless Go & push-start on shifter; could it be the remote battery dying(just came to mind)??
Thanks for any help, D
Old May 20, 2014 | 12:49 PM
GT854T5's Avatar
Hi plutoe- I would say it doesn't seem like a programmed sound in the cluster. It sounds like the chime/sound is coming from somewhere in the middle of the car; like center console/rear AC vents area. Since it happens so quickly, I can't pinpoint the area exactly. I guess the question to ask is: What are ALL of the instances when an alarm or chime will go off in 05-W211? That way i can eliminate what is not happening in my car?!?!? does that makes sense?
thanks for any input.....
Old May 20, 2014 | 12:52 PM
Honcho's Avatar
'03 SL55 AMG | 2021 AMG GLE 63s Coupe
Hmmmmm... Do you let small children with electronic toys in your car? Small electronic toys that could get wedged somewhere annoying? :-)
Old May 20, 2014 | 02:12 PM
GT854T5's Avatar
@Honcho- I acually don't have toys/small kids in the car. Hmmmm, maybe the previous owner did and a toy is stuck somewhere with a dying battery!?!?!?! Will look into that....
Thx, D
Old May 21, 2014 | 09:42 AM
Barry45RPM's Avatar
2015 ML 350
I had a fully loaded 04 E500 (sedan) years ago that would emit a high pitched beeeep every so often randomly. The best I could do was identify it was coming from somewhere over the drivers left shoulder rearward.
Back then, the common belief on the forum was that it was a kinked air hose from a rear compressor that was feeding the air bladders in the dynamic front seats which would wheeze from the kink in the air line every so often.
Do you have dynamic front seats? Not sure if this applies to you, but I'm throwing this out there. If it was a warning beep, it would come from the dash.
Old May 21, 2014 | 01:58 PM
GT854T5's Avatar
Hi 45RPM- By George, you may have found the problem; I DO have dynamic seats! How did you resolve it??
I will check around under both front seats to see if any kinking is happening.
@plutoe- I didn't see the attachement; what was it about?
Will report by in a day or so my findings......thx.
Old May 21, 2014 | 06:31 PM
Barry45RPM's Avatar
2015 ML 350
I believe it was either behind/below the rear seat or elsewhere on its route to the front seat from the trunk. We never found it but a few others did. (Others never did). I just remember that it was a king in the line. I learned to ignore it and at 3 yers/36000 miles bought my '07 E550 without drive dynamic seats.
Old May 21, 2014 | 07:52 PM
LemonSqueezy's Avatar
14 550 sedan
I wonder if this is the same problem I've been having recently. I sometimes get this weird chime/bird chirping sound when I accelerate.
