Airmatic Mistery
I have an 2004 E320 with airmatic suspension.
The passenger back side started to lower; the indie shop performed a diagnostic and told me that the pump was about to fail. I just replaced the pump (myself) and noticed that with the car raised (the button on near the shifter) the rear suspension does not lower at all.
This may be a case of a bad valve? or do I still need to replace the rear Shock?
I'm not using the car just in case... I do not want to replace the pump again.
Thanks for the imput
My mechanic does have a DAS Xentry and the pump was not charging at the pressure it is supposed to work and since it was working extra to keep the car up came the correct conclusion: "the pump is about to fail".
I'll post the results of my endeavour for the enlightenment of whoever want to read it.
Bottom line, you both need a DAS hooked up to your cars to read the diagnostic codes.
I'm going to get a beer out of the refrigerator....
