Grinding sound and vibrating when steering wheel is turned
Like I said in the title, on my 2006 E350 4matic, when I turn the steering wheel to make tight turns, u turns, or just a slightly sharp turn, I hear a grinding sound and the car vibrates. Someone told me that it is normal on MBs that have high mileage (132k) with 4matic. If anyone could help me out I would be grateful. Its an awesome car and I really like it, and I would rather not have to sell or rip apart the whole car to get it fixed.
Probably some steering components. My suggestion is to take out the wheel and inspect visually.
Steering wheel squeak and grind could be eliminated with the use of Lubrizol which is a MB product for that purpose as well as stop leaks. You should probably consider doing power steering fluid service and add Lubrizol to the fresh fluid.
Originally Posted by Stuttgarten
(Post 6168709)
Have you had the engine &/or Transmission mounts checked?
Originally Posted by omarzamani
(Post 6168715)
I see how this could be a solution, but I think you misunderstood the problem. There is nothing wrong with the steering. It steers perfectly and easily. The problem is that when I turn the steering wheel all the way or close to all the way, the car itself shudders and vibrates and sounds like something is grinding against another. I could be wrong but I have a feeling it isnt the power steering fluid but im planning to get and oil change soon as well as some other service so I will add that to the list. If anyone knows, could it possibly be an alignment issue?
Try turning it in park.Try turning it parked and in drive mode. Let me know and then we can help U better. |
(Post 6168538)
If its actually the entire car that is doing it, change the transfer case fluid (might as well do the front and rear diff while your at it) assuming its never been done. I had mine changed at 70K miles when I bought it, and the issue went away.
Originally Posted by dewana421
(Post 6169678)
Does it do it only when u drive or even in park?
Try turning it in park.Try turning it parked and in drive mode. Let me know and then we can help U better. Thanks |
Originally Posted by rodneypierce
(Post 6170741)
It is hard to diagnose from the printed word, but don't overlook your power steering pump. I found the fluid needed to be changed to keep it working properly. No I didn't drain it, I only suctioned it empty topped off with proper fluid, drove 50 miles repeat, did this 3 times and all pump noise was gone
DTB P-B-28.50/11 is the transfer case # Have them check it out. It was only the w211 2005-2007 4matics as far as I can tell.
Does it clunk sound like a roller coaster?
Originally Posted by jaxfl
(Post 6171290)
Originally Posted by MProved
(Post 6171319)
Check all your RUBBER mounts. I just replaced a bunch of them in my 2006 that had rotted or broken or cracked and I did have some cluck before that.
also check this thread https://mbworld.org/forums/mercedes-...g-turning.html |
So I called MB today, and I was told that the service campaign for the transfer case was closed in 2013, but I have been told by other people that service campaigns and recalls do NOT expire. I am thoroughly disappointed...
Call another MB Dealership... maybe even 2 more and see what they say.
I called mbusa, and they told me my car isn't included in the service. Even though I have the same problem as it. Does anyone know if it can be harmful to my car if I drive it over a long period of time without fixing this? I will change the oil in the transfer case soon but a new transfer case costs a few thousand dollars and I cant do that right now.
Ive had some grading noise when i was turning. Went to the shop they couldn't figure it out. Then i went to autozone and bought wd40 removed the wheel check everything myself. Couldn't find anything and just sprayed every joint component, connection and bushings. Never had any noises after that.. Those connection can get squeaky especially after rain.
Originally Posted by despicable merc
(Post 6171809)
2 Attachment(s)
(Post 6172100)
But it isnt a noise, rather more like a feel with noise. I can feel the car vibrating and something grinding against another when turning. Also that does come along with noise so I will try what you said. Did you do it on the front and back?
Attachment 397946 That's what i did.. I know its sloppy fix. Try to spray these areas Attachment 397947 |
(Post 6172153)
Front.. There's nothing at the back. See if you have cracked bushings.. If yes then fill it with some lubricant. Control arms have rubber bushings filled with lube and if they cracked they will make noise.
http://i1324.photobucket.com/albums/...psb5fgw9gj.jpg That's what i did.. I know its sloppy fix. |
Just from your title this describes a bad wheel bearing issue exactly...
Originally Posted by AMGAffalterbach
(Post 6172223)
