E-Class (W211) 2003-2009
DAS Xentry... Why Dell D630
Old Sep 17, 2014 | 08:58 AM
Honcho's Avatar
'03 SL55 AMG | 2021 AMG GLE 63s Coupe
Question DAS Xentry... Why Dell D630
Nearly all SDS packages for sale seem to come with an old Dell D630. Is there some reason for that other than the fact that the D630 is inexpensive?
I found this: http://*******.com/Thread-DAS-Xentry...0-D630-Acronis which says DAS Xentry can be loaded onto any laptop.
Old Sep 17, 2014 | 11:50 AM
cetialpha5's Avatar
It's probably because it has a real com port. Most laptops these days have just a USB port and things don't always work right if you're using a USB to RS-232 converter. You wouldn't want to brick a component during an update if you're using USB. The other option would be to get a C4 system, but then they cost more. I think there are a couple other systems out there like IBM that also have real com ports.
Old Sep 17, 2014 | 12:05 PM
Honcho's Avatar
Is there any worthwhile benefit to getting the C4 versus C3 version of the SDconnect multiplexer?
What are the "Green Network Cable" or WiFi, and
8, 14, 16, and 38 pin cables used for?
Old Sep 17, 2014 | 12:22 PM
cetialpha5's Avatar
Not sure about specific benefits, that might boil down to how many cars you're using it on. For just one car, C3 is probably fine. I think those other cables are for different cars, they had different connectors on different years and models. I've just been looking into getting one so someone else will probably know better. It doesn't seem to get much cheaper if you find a package that doesn't have those cables, the expensive part seems to be the mux. Cheapest C3 setup is probably in the $300-$400 range and C4 is a bit over that.
Old Sep 18, 2014 | 11:43 AM
Honcho's Avatar
Excellent info..... Thank you Plutoe.... that makes deciding which way to go a lot easier.
WinXP is going to be tough to find, so something that runs on Win7 is preferable.
So the WiFi option doesn't free it up from any cables or make it more convenient in any way? I probably will want to gather data "on the road"
Learning the system is "via F3" doesn't excite me, but oh well
