E-Class (W211) 2003-2009
air suspension problem help 03 w211 E500
Old Sep 23, 2014 | 06:41 PM
bigd540's Avatar
E500 2009 and Cadillac Deville 05
To start off the car was saying too low stop driving then the back of the rear suspension dropped down to about a inch from the ground so I parked then I did some research online trying to troubleshoot the problem the best way and I came to the conclusion that the air compressor may be bad so I just change the air compressor today connect it all back up and then I noticed the holes that comes from up towards the engine with the filter had been disconnected from somewhere but I don't know where so that's why I'm writing this today hoping that somebody can let me know where I can connect this back up too?
Old Sep 24, 2014 | 12:35 PM
DanG2's Avatar
04 E500
Is this what you need? https://mbworld.org/forums/e-class-w...ml#post6126431
I seem to recall there were a couple of additional posts that don't show up in the thread above. If I remember correctly there is a clip on the back of the front bumper in the area in front of the compressor that the hose fits into. Anyway, if you look in that area you I expect you should be able to figure out where it goes.
Old Sep 26, 2014 | 09:17 AM
vettdvr's Avatar
03 E500 and Corvette
If the rear are low and the front is not the compressor is working. You have a leak in the rear airbag system. It might be the line to the accumulator surge tank but my guess is the bags have a hole in the fold at the bottom of the bag. New bags (air springs) will probably solve the problem.
Old Sep 26, 2014 | 11:04 PM
THE Rooster's Avatar
03 Mercedes E500, 74 Vette, 93 Mirage River Racer 111mph. in 12 seconds, 94 Lincoln Mark VIII + NOS
Great info here and a helpful link.
Old Sep 30, 2014 | 09:50 AM
bigd540's Avatar
Thank you all for the feed back now the pump cut off after running for about 5 seconds then shut off.
Do anyone know where I can get some rear air suspension bags for a reason price on the the wed?
