E-Class (W211) 2003-2009
Old Jun 12, 2015, 06:55 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Interior Guides
Print Wikipost
W211 Car audio upgrade
Old Jan 26, 2015 | 11:14 AM
Pasquale545's Avatar
2004 Mercedes E320
This is just a post for anyone that whats to upgrade the car audio system in their W211.
You can absolutely upgrade your system and put a double din, you just have to put a new amp in your car (you can also keep your original speakers if you want). Since your putting a new amp, you bypass the fiber optic system.
Old Jan 26, 2015 | 02:53 PM
rediesel's Avatar
2006 E320 CDI 2014 C63 507 Coupe 2012 E550 4M 2016 E63s Wagon
How did you get the steering wheel controls to work? Does the audio information still display in the instrument cluster?
Old Jan 26, 2015 | 03:00 PM
agm18's Avatar
2006 4Matic wagon Elegance, Infiniti 2004 G35 Sport, 1969 Jaguar XKE (s) 1988 Camaro Convert (s)
What amp (brand) would you recommend?
Thanks,
agm
Old Jan 26, 2015 | 03:01 PM
2004 Mercedes E320
yes you can have steering wheel controls, use the module axxess aswc-1 i believe is the model
Old Jan 26, 2015 | 03:05 PM
2004 Mercedes E320
Thanks,
agm
The best amp (for me at least) is the Alpine 5 channel amp PDX-V9
this amp is small, amazingly powerful and can do a full system including subwoofer
4 channels x 100 RMS (for all your speakers)
1 x 500 RMS (for the subwoofer)
The RMS is alwasy tested higher that whats on the box
My system is 2 sets of Focal KRX 2 speakers for front and rear
and 10w3v3 Subwoofer all run off the alpine
Old Jan 29, 2015 | 08:23 PM
indy790's Avatar
2005 e320 cdi 1996 acura nsx-t 2014 acura RLX
bypassing the fiber optics
Hello
Did you have to run all new wires to the speakers ?
Also do u have to use an adapter to bypass the factory amp ?
Old Jan 30, 2015 | 09:10 AM
boardboy330's Avatar
2000 ML320, 2005 E320 CDI
Originally Posted by indy790
Hello
No. You can tap in to the wires in the trunk and run a set of AUX leads to the head unit.
Old Jan 30, 2015 | 07:09 PM
a100steaksauce's Avatar
W218
pics?
Old Jul 18, 2015 | 02:52 AM
tubaprde's Avatar
E55, past: SL55, 560SEL
Are you disconnecting the center speaker with this setup? Do you lose the "pro-logic-7" sound?
