Both side markers out
Started the car yesterday and got messages for both (left/right) side markers out. I was immediately suspicious as what would the odds be for both bulbs to burn out... so I suspected a wiring issue. I turned lights off and then back on watching the left side marker. It came on when I switched the lights on but after a second or two it flickered and went out. I had spare bulbs so I went about replacing them to see if that would help. I started on the right side and when I pulled the bulb out I noticed the connector was full of water. I blew the water out, sprayed with contact cleaner, changed gasket and replaced. I went ahead and changed left side as well (it was dry). Lights then functioned as they should. I believe that the problem was water in the right marker and it was shorting out which then caused the left marker to go out. Neither bulb looked to be burned out. I'm pretty sure I could have just blown the water out and put the bulb back and all would have been fine.
