E-Class (W211) 2003-2009
LIMP MOOD ANY ONE WITH INFO?
Old Apr 21, 2015 | 02:58 PM
kostikabenz's Avatar
2004 mercedes cl 500
I have a 2003 e320 was sitting for long time, now have a problem with limp mode the vehicle stuck in one speed and does not change gears, the screan shows ESP, ABS, BAS and Malfunction electrical consumers switched off, have replaced couple parts :
- conductor plate,
-wiring connector
-ABS rear left sensor
-auxiluary battery
-rear battery
-tranny oil level is good
and Im still having the same problem i clear the codes and the same codes come back after driving 30 seconds.
p20ca, p20cc, p2400.p2401,p2403, c1439,c1479,c14be codes coming up please help guys
Old Apr 21, 2015 | 04:49 PM
cmriv's Avatar
2009 E550 2000 Honda civic mash n' go
- conductor plate,
-wiring connector
-auxiluary battery
-rear battery
VALVE BODY MAYBE. .6 TRANS ARE PRETTY SIMPLE. CAN YOU LOOK AT YOUR ADAPTATION VALUES...? MAY NEED A NEW TRANS....
Old Apr 21, 2015 | 07:50 PM
S430LUCKDRAGON's Avatar
2003 S 500 4 MATIC , 2001 S 430 , 2003 ML 500
Did you try cleaning out the TCM with electrical cleaner ? Some times the tranny fluid makes its way into the unit itself
Old Apr 21, 2015 | 10:00 PM
thanks for the reply tomorrow i will be sending the car to fully diagnostic again, yea I hope that is the transmission, yea the tcm is clean no oil or anything like that. I have notice that i do not have a relay on the top of my battery could it be the source for all that? because i have read on previous posts that there is suppose to be one
