found out why the car vibrates"with video"
i have now changed the brake disc, and brake pads, and parking brakes, and it still wobbles, can it be a bad abs sensor?, cause it seem like it is brakeing, or something like that.or can it be a bad shock?cause it is some play in the side where the sound is, on the other side it is firm, and no play
need some help here
Lars
need some help here
Lars
no i just have lifted it from the ground with all 4 wheels.i have never heard about the dyno mode.
i also feel something knocking in the thrust arms,when the rear wheel jumps..
i have ordered some new shocks, and a pair of thrust arms
could it be the diff??
Lars
Lars
You need to put your car in dyno mode. Your esp is going crazy and your burning you abs module up by just driving in regular mode on jack stands... I'm sure you wont hear any of these knocking noises or thrust arm noises when your car is in dyno mode. You are just freaking your esp module out cause it can't tell whats going on because all your wheel speed sensor's are calculating different values.... Which in return causes your esp to stop supplying power/stopping your wheels from moving...
