Help navigation WIS
So I have read my fault code but now I want to see what WIS says to check and or replace for that fault. I have looked everywhere and I cannot find where to find fault codes on Wis.
That's cool, however which tool did you use to read the codes and were all the faults that were read have a prefix of "P"----if that is the case then simply open WIS put you VIN in---then check all the boxes on the right side of the screen----then--start search---then go down to mixture info---check box--then click get documents----now you carefully look at each title untill you find one that indicates faults---open the document----voila!!!
I will try that tonight. Thank you for the help.
